My First ZOOK!
10 Oct 2020 12:23 #228984 by mlines
Replied by mlines on topic My First ZOOK!
You have a message...
10 Oct 2020 13:41 - 10 Oct 2020 13:45 #228989 by mlines
Replied by mlines on topic Re:My First ZOOK!
This is the button I meant
If you get really tired of it I could try and read it if you post it to me
(P.S for anyone looking at the above picture, thats a tyre depots idea of the correct pressures after changed tyres!)
Last edit: 10 Oct 2020 13:45 by mlines.
10 Oct 2020 14:37 - 10 Oct 2020 14:38 #228992 by mlines
If you go down getting more sensors, they do not need re-programming, the system should re-learn. So suzuki would say its a simple swap for wheels with sensors in. Just put the new wheels on and drive off.
However, despite what the manual says, it it not always quick and successful. Ours took the best part of a 90 minute drive to pick up a sensor so sometimes the option is to just drive around with the warning up and wait for it to clear.
If you wanted to send the Irongate module to me I can see if it puts out a TPMS signal. Where do you live? I fancy its a little too far for a diagnostic visit, I am near Reading
Last edit: 10 Oct 2020 14:38 by mlines.
The following user(s) said Thank You: DAGZOOK
10 Oct 2020 14:43 #228993 by Roger Fairclough
Replied by Roger Fairclough on topic My First ZOOK!
Hang on a minute, you can't blame Suzuki for fitting a system that is a legal requirement! You no fit em, you no sell em.;)
Roger
10 Oct 2020 14:46 #228995 by mlines
One further thing. If you do the manual reset process (which means you do not have to wait 20 minutes or drive the car then the TPMS light shows the status of both the reset and the re-learning process.
It flashes every 0.5 second when no sensors are found.
It flashes the number of REMAINING sensors to be found as it finds them.
So when it has found 1 sensor, it flashes in bursts of 3 (3 left to find(
When it has found 2, it flashes in bursts of 2 (2 left to find)
When it has found 3, it flashes in bursts of 1 (1 left to find)
When it has found all four it comes on solid for 5 seconds and clears.
10 Oct 2020 14:47 - 10 Oct 2020 14:47 #228996 by mlines
Roger Fairclough wrote: Hang on a minute, you can't blame Suzuki for fitting a system that is a legal requirement! You no fit em, you no sell em.;)
Roger
You can blame them for a system that does not work in a reliable and predictable way. :)
Last edit: 10 Oct 2020 14:47 by mlines.
Time to create page: 0.254 seconds
