Re:The Jimny of the Yakuza
- OlaGB
- Visitor
Was the gear shift mechanism on the box, or did you reuse youre old? I`m wondering why the shifter feels tighter, usually only due to bushings.
- Thank you received: 333
Could also be the clutch releasing better.
Even though the clutch now grips lower on the pedal adjusting the wire more correctly.
- Visitor
That is when the clutch wire and brackets begin to bend and stretch over time i guess..
With a better quality clutch the systems total balance and thus its function gets to be way better.
-in theory
Do you have a definite list about R72 type (year 2005) gearbox? I mean which parts should be replaced with new/upgraded parts in order to improve reliablity of this type?
I bought and got fitted another used R72 type gearbox last summer so I have the old one ready for rebuild.
My old R72 type gearbox has good gears but sync rings and bearings may need to replaced with new ones hence I'm asking.
Thank you for any advice.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
HUN wrote: Hi Yakuza.
No I do not have such info other than the bearing kits on ebay has closed bearings, my 2013 gearbox has closed bearings as i have seen with my endoscope, and my 2005 box had open bearings. this upgrade came 2009/10 i have read somewhere. (in here i think?)
The refurbished gearboxes sold have new gearwheels, bearings and sync rings one seller told me.
I too have been thinking about rebuilding and upgrading my used and crashed gearbox. But it would need most gearwheels and of course everything else in there that is damaged. I would have to check shafts and housing thoroughly so I might just do a core swap when i buy a new or refurbished gearbox sometime in 2026 when this new one breaks down...
Or more correctly the drive shaft is leaking ref. this post: www.bigjimny.com/forum/7-jimny-technical...ain-grrrr.html#71942
the shaft is leaking inside the spline yoke. Seen some seal it with silicone.
I'll try to clean it with brake cleaner spray and seal it with Tec7.
So will start to find a drive shaft from a newer car if possible.
Not many of those here in Norway, I know of the car i got the gearbox from only.
The dog and I fixing the horse track for the kids with a harrow..
- OlaGB
- Visitor
OlaGB wrote:
That dog would probably pull that harrow too
He should be capable to do that, but he is probably the most useless lump of protein in Western Norway.
Sent fra min E5823 via Tapatalk
Found my synchronizer ring on the 4x4 front output had broken.
I must have done something stupid while trying to get the case back together that broke the ring, or it was broken before.
It was very troublesome to get the box together as well and i did not get it to shift properly so trying to order a new ring today.
So now I await my local Suzuki dealer and hoping it can be sourced within reasonable time.
