Gaz's reasonably priced jimny..
- gaz3359
- Visitor
I got the car recovered back home due to a collapsed osf wheel bearing and imediatly set about removing the hub.(i can do all the repairs myself been a time served tech)
After fitting the bearing i thought first thing was to go for a slow local drive to see what was what,this wasnt good,the brakes hardlys worked pulling terrible to the left,there was lots and lots of play in the steering,and when putting it in 4wd it was evidedent that the osf cv joint was completly shot the banging was terrible.so after jacking it up and having a look round i needed,x4 king pin bearings as they were all shot and guessing had been like that for a long time,i got 2 sets of wheels with the car and 4 of the tyres were scrubbed indicating the bearings had been like this,osf cv joint,a osr axel oil seal as fluid was dripping from the back plate.and a full brake strip down check and over hall.not many pictures as said.
after doing all of the said things above,and i found that the slides in the calipers were nie on siezed so all freed off and rears cleaned and adjusted i no had a jimny that drove id say now safely.after a road test it was clear the jimny was suffering from the "death wobble".when i ordered the bearings a ordered a shim kit so after some tweaking ive got the wobble nie on gone and this is without balancing any wheels yet,so quite pleased.
Id gave the jimny a good once over,removed the rear tints,removed all of the chrome as this was not for me,found a small ammount of corrosion in the boot the usual place i treated these and hammerited them as its still pretty solid hoping they will pass a test.i also had to do some repairs to the wiring for the front lights as the jimny has had some spot lamps fitted and found that scotch locks and wires just twisted together were the culprit so soildered everything up and they now all work.i was now happy to put the jim in for a test even tho it wasnt due till the end of the month this would give me time to sort any problems thats picked up.
picture before dropping off for test.
The jimny passed with a couple of advisarys,i know the mot place but they dont turn any blid eyes to anything id rather know if there was problems.
The advisarys were osr brake just met efficency this was the side that was soaked in diff oil so i whipped the drum off again brake cleanered the shoes again and nipped them up seems ok now.
The corrosion i found was advised but he said theres nothing to worry about was happy with that.
He thought there was some play in the nsf somewhere now he knew id replaced all the king pins as he could see all the gasket sealer and where everything had been cleaned.when i got back from the test centre i could still feel a bit of play/knock in the steering so after jacking the nsf up there was no play in the wheel at all so i dropped the car down and got my dad to work the steering wheel and you could hear a slight clunk after looking about and swinging off this i found that the panard rod on the ns was loose after removing the that was siezed in i cleaned all the treads refitted and tightened that was that all the play gone drives so much better.
Next was the emmissions he said it had just scraped through,now after this it got me thinking,the jimny does seem heavy on fuel in fact worse than my old 300tdi disco that had done 220000 miles.after working out my mpg's im averageing around 18-20 mpg
![:ohmy: :ohmy:](/media/kunena/emoticons/shocked.png)
![:( :(](/media/kunena/emoticons/sad.png)
I still have a fair bit of jobs stuff i want to do to the jimny but its and on going thing,ive sold alot of the standard chrome and sold it on giving me a bit money back in all helps,ive also bought off nezzy55 on here a set of white modulars 8 spokes with insa sahara 195 80 15's with 32mm spacers to fit,ive also got a 2" spring spacer lift coming.ive also got a friend fabbing me up some recovery points ,after fitting these this should get me out playing with my mates fingers crossed.will keep updating and try get more pictures lol thanks for looking so far
Gary
- goatboy
- Visitor
Glad you are getting it sorted, taking out the engine check light is very naughty of someone!!
![:evil: :evil:](/media/kunena/emoticons/devil.png)
- GuardianAngel
- Visitor
![:p :p](/media/kunena/emoticons/tongue.png)
- Tadpole
- Visitor
![;) ;)](/media/kunena/emoticons/wink.png)
- Dan_w
- Visitor
it may be worth getting some of martins shock relocation brackets to give a little more travel in the rear shocks, when I had my spacers in with the standard shocks it was quite harsh over speed bumps before fitting the brackets.
- reaper
- Visitor
- gaz3359
- Visitor
- gaz3359
- Visitor
new rear number plate the number makes me laugh a bit,bet people were calling me a kox when going sideways past then in the snow
![:laugh: :laugh:](/media/kunena/emoticons/laughing.png)
When i got it i noticed that the rear wiper stopped when at the full sweep,i put this down to a siezed motor and ordered a new one,but the other day i noticed something about the spare wheel it didnt look like it was sitting right,after closer inspection the tailgate has taken a knock and its bent in over a bit.thus causing the wiper arm to get stuck against the tyre.need to have a think on this one
Also the top tailgate hinge had dropped so i removed this today
Ive had a right fight with it today,took it over to the garage i work at (when its busy,im self employed and not there much at the moment always the same in january,hence how i have a bit of time to do odds and sods on the jimny during the day) rather than replace it i was confident i could bodge sorry repair it lol,had to tap out the old snapped pin with lots of shouting,a couple of drifts and heat,got there in the end i just need to tidy it up fit my makeshift pin and put a layer of paint on it then i will refit this tomorrow.
- Dan_w
- Visitor
gaz3359 wrote: Thanks for the great replys its appreciated,ive just re-read my write up theres a few mistakes but i was in a bit of a hurry this morning when i done it.to note ive got shock extenders coming aswell.
Good stuff you are one step ahead
- nezzy55
- Visitor
- craigy123
- Visitor
