4wd 4l overheating
17 Nov 2024 15:28 #258355
by nickcot
Replied by nickcot on topic 4wd 4l overheating
it wasnt the fan, the problem is mainly that is smells like burned steel and it mainly is when the 4wd is working, the drive the rest works normal, no problem no nothing
- Thank you received: 1806
17 Nov 2024 15:43 #258356
Replied by Lambert on topic 4wd 4l overheating
Take it to a professional specialist mechanic.
17 Nov 2024 16:17 #258357
by jlines
Replied by jlines on topic 4wd 4l overheating
As others have said you need to get the car inspected by a mechanic or your trusted suzuki dealer. No one on here can diagnose a problem on a car they can't see. How muddy was this track you were on? Was the car covered in mud? Was the Radiatior full of mud? From your posts it sounds like you've overheated the engine but now its driving fine with no lights or warnings?
- Rogerzilla
- Senior Member
- Thank you received: 10
17 Nov 2024 16:40 #258358
by Rogerzilla
Replied by Rogerzilla on topic 4wd 4l overheating
It was certainly the case in t'olden days that a car which had boiled its coolant, which wasn't unusual in hot weather when everything had a belt-driven fan, needed a top-up and all was usually fine. Alloy heads and blocks make it more risky but the 1.5 engine may well be tougher.
