4wd 4l overheating
14 Nov 2024 20:29 #258307
by nickcot
4wd 4l overheating was created by nickcot
hello
today i was using my suzuki jimny 2021 that has a cream color i think its called ivory and i was climbing a very muddy road which i have climbed before, the thing is i put my 4l and when it slips i hit on the gas a bit until it advances and this time it starting smoking from the front hood, i thought it was going to ignite in fire but thanks God it didnt go for worse, i descended the hill and have been using it normally so far no problem, have anyone had a similar situation?
regards
regards
14 Nov 2024 22:36 #258308
by Busta
Replied by Busta on topic 4wd 4l overheating
Did the engine overheat? Sounds more like water or mud splashing onto the hot engine and exhaust.
- The Coil Spring
- Thank you received: 2
15 Nov 2024 01:21 #258310
by The Coil Spring
Replied by The Coil Spring on topic 4wd 4l overheating
White smoke means water that vapours (coolant or as Busta says, water from outside), black smoke is a blown cylinder head.
15 Nov 2024 01:56 - 15 Nov 2024 03:19 #258311
by nickcot
Replied by nickcot on topic 4wd 4l overheating
it was indeed the engine because the coolant reservoir started bubbling and there was vapor coming from the green cap and there was white smoke
i tried taking a quick videeo, you can see the coolant bubbling from the overheat
streamable.com/xxdxi9
this is all i had everything happened too quick
by the way i just saw in the manual that 4l needs to be slow, i cant like go too quick, ill trry using 4h but just wanna know, is there something i can do to see if there was any damage? how can i check the 4l 4wd transmission and whatsover to see that there was no damage to the engine or so
regards
regards
Last edit: 15 Nov 2024 03:19 by nickcot.
- Thank you received: 487
15 Nov 2024 10:42 #258320
Replied by DrRobin on topic 4wd 4l overheating
What was the air temperature when the engine over-heated?
The fan should have kicked in long before the engine got this hot, did you notice if it did fire up? The fan should be able to control the temperature even when stationary, unless it was really hot outside and you were hitting high revs under a lot of load for some time.
The older 1.3L Jimny used to suffer from head gasket problems if the engine got this hot, I am not sure if the same happens with the 1.5L (2021) but it is not good for any engine to get this hot.
I doubt there will be any difference between 4L & 4H, your engine has to produce the same power and if the outside air temperature is the same, the engine will get just as hot.
16 Nov 2024 21:02 #258346
by nickcot
the temperature was red, the thermostat turned red, i mean i dont have a thermostat at hand to know these things, the manual says to use 4h for normal speed and dont go high revs on 4l, i really dont know if i should check anything so far, the road was muddy and inclined, the answers are not helping much
16 Nov 2024 22:06 - 16 Nov 2024 22:06 #258347
What you have described is not normal.
What was the outside temperature, your car shows this on the dash board?
How long were you driving up this muddy hill?
Was the engine temperature normal before you started on the muddy hill?
Last edit: 16 Nov 2024 22:06 by DrRobin.
- Thank you received: 1806
16 Nov 2024 23:11 #258348
Replied by Lambert on topic 4wd 4l overheating
As said above this is not normal. By virtue of steam/ smoke/ vapour coming from the engine bay you have obviously done something that has stressed the engine/put it under too much load for too long. I strongly suggest you have it properly investigated by a suitably qualified garage be that the main dealer or other specialist in jimny local to you. It's not simply going to get better by itself. You need someone to confirm that you don't have exhaust gasses in your coolant and that it has correct compression on all cylinder as a minimum check on the engine health. You might be lucky but I wouldn't count on it, you could just as easy hurt it quite badly.
- The Coil Spring
17 Nov 2024 01:22 #258350
by The Coil Spring
To me your description of events sound like the cooling fan isn't coming on when it should. Have you checked it?
- Thank you received: 30
17 Nov 2024 09:35 #258351
by Motacilla
Yes, you quite possibly damaged your engine and it needs to be checked by a professional. They have tools and experience that you do not have, and we can't help you with.
No, there is nothing you can easily check "to see that there was no damage." Boiling and/or exhaust-contaminated coolant is already a sign that there was potentially damage to one or more components.
Your choice is: go immediately to the professional shop to get it fixed, or don't. If you choose the latter, you might save money in the short term, but will almost certainly spend more in the long term.
Good luck to you
Replied by Motacilla on topic 4wd 4l overheating
Nickcot, maybe this answer will help.is there something i can do to see if there was any damage? how can i check the 4l 4wd transmission and whatsover to see that there was no damage to the engine or so
Good luck to you
- Rogerzilla
- Senior Member
- Thank you received: 10
17 Nov 2024 09:37 #258352
by Rogerzilla
Replied by Rogerzilla on topic 4wd 4l overheating
The gen4 has an electric fan so this is a possibility. Could also be a stuck thermostat but they usually last > 10 years easily.
When you say the temperature was red, did you get a red warning light? I don't think the gen4 ever has a proper gauge.
- The Coil Spring
17 Nov 2024 11:51 #258353
by The Coil Spring
It is correct that the gen 4 doesn't have a gauge, disappointingly. Instead there is a warning light that looks like this:When you say the temperature was red, did you get a red warning light? I don't think the gen4 ever has a proper gauge.
