Manual 4WD - 4H 4L in display?
21 Nov 2023 07:49 #252255 by Narge
Am I right in thinking that going in to 4WD using  manual 4WD gear lever does not display 4H or 4L on the instrument display but only a 4WD light?
Many thanks
21 Nov 2023 08:11 #252257 by Pondboy
My Gen 4 shows the same 4WD icon for both high and low. No other indication of being in low.
PB
Sent from my IN2013 using Tapatalk
21 Nov 2023 08:13 #252258 by DrRobin
My 2011 Gen3 shows 4WD and 4WD-L when in 4WD modes. I don’t know which Jimny you have?
21 Nov 2023 09:32 #252259 by Busta
That is correct. On pre-2005 models only a 4wd light shows. There is no indication of low range other than the position of the stick.
21 Nov 2023 10:51 #252263 by yakuza
Even my 1984 Jimny gen 2 got a 4wd light, so 1984 to 2004 then :)
2005 got the 4wd lo as well.
Mine is now blinking and flashing sometimes the 4wd light one blink or double speed, and sometimes the 4wd-L blinking with doublespeed.
Only does this when below -2.
Very annoying as it works fine at above zero and I got this large battery in the way of the solenoids and it is very cold outside.
  • rogerzilla
21 Nov 2023 11:34 #252264 by rogerzilla
Replied by rogerzilla on topic Manual 4WD - 4H 4L in display?
You only need the 4L light on push-button Gen3 cars, because there is no other indication available (except a racing engine!).
Time to create page: 0.287 seconds
