Manual 4WD - 4H 4L in display?
22 Nov 2023 12:51 #252292
by Narge
Replied by Narge on topic Manual 4WD - 4H 4L in display?
Thanks for all your technical knowledge!
Yes, my Jimny is pre-2015 with manual gear shift 4x4 selection so confirmation that there would only be a 4WD light in dash and no Hi or Li light has really eased my mind.
22 Nov 2023 15:04 - 22 Nov 2023 15:05 #252295
by facade
I believe "They all do that Sir!"
Compared to the Gen 3 where I just snicked the lever back, let go and the detent knocked it into low, having to really be determined and force the thing past what feels like the engaged position definitely feels like something is wrong- I keep the pressure on when I put it into drive to make sure it is in now, luckily with an auto, you don't need low very often.
Replied by facade on topic Manual 4WD - 4H 4L in display?
I thought I was the only one that needs to hammer the 4L I don´t need to use it much, but when I do I am always like "oh well, here we go again". It usually takes me 2 or 3 tries!
Last edit: 22 Nov 2023 15:05 by facade.
- Roger Fairclough
- Thank you received: 225
22 Nov 2023 17:25 #252296
by Roger Fairclough
Replied by Roger Fairclough on topic Manual 4WD - 4H 4L in display?
Please don't take this the wrong way, but you pull back to engage 4 wheel drive high range - green light on dash indicating 4wd - and then you push down and pull rearwards to engage 4 wheel drive low range. In this position various other lights come on and the green 4wd stays on. Now I haven't checked it but the fact that the other amber lights come on is probably an indication that low range has been engaged. As I said, I mean no disrespect.
Roger
Roger
22 Nov 2023 22:54 #252313
by facade
Seems like a design fault to me and we are being collectively fobbed off by Suzuki, the selector obviously moves far enough to activate a switch, but not quite far enough to engage the gears, you'd expect a detent plunger to complete the selection and lock it in low if you were almost home- maybe the detent groove is too wide.....
When it is actually in low, mine doesn't jump out- yet, but I'm worried it might when the transfer box is out of the extended warranty.
The problem with the Gen 4 is that when you push down and backwards until the lever feels like it has moved fully into low, the dash plays a tune and all the lights come on alright, but more than 50% of the time it is in a false neutral and there is no drive.Please don't take this the wrong way, but you pull back to engage 4 wheel drive high range - green light on dash indicating 4wd - and then you push down and pull rearwards to engage 4 wheel drive low range. In this position various other lights come on and the green 4wd stays on. Now I haven't checked it but the fact that the other amber lights come on is probably an indication that low range has been engaged. As I said, I mean no disrespect.
Roger
- Roger Fairclough
23 Nov 2023 08:53 #252319
by Roger Fairclough
Like most things in a g/box / t/box, all the bits that can change settings need usage to polish moving parts and ease engagement so I must remember to engage high and low range 4wd from time to time so that any problems are allowed to rear there ugly heads.
Roger
Roger
25 Nov 2023 18:58 #252382
Replied by jackonlyjack on topic Manual 4WD - 4H 4L in display?
Just a quick question has anyone removed the gator to see if leaver is obstructed
This problem arrises on a Gen 3 when a body lift is fitted.the leaver hits the body work and jumps to false neutral.
Just a thought
Just a thought
The following user(s) said Thank You: facade, Roger Fairclough
Time to create page: 0.317 seconds
