Manual 4WD - 4H 4L in display?
26 Nov 2023 13:02 #252395
by facade
I suppose they could have measured wrong or just used the measurements from the early Gen 3, and the Gen 4 box could be slightly different.
When the weather warms up next Spring I'll try to remember to have a look next time I put it in low.
Replied by facade on topic Manual 4WD - 4H 4L in display?
I knew about the body lift causing a problem with the lever fouling on a Gen 3, but it never occurred to me that the designers of the Gen 4 would make such an elementary mistake- if they had surely there would be a service bulletin "In case of repeated customer complaint, pull the gaiter and cut a 10mm groove in the body" or similar.Just a quick question has anyone removed the gator to see if leaver is obstructed
This problem arrises on a Gen 3 when a body lift is fitted.the leaver hits the body work and jumps to false neutral.
Just a thought
- Roger Fairclough
- Thank you received: 225
26 Nov 2023 15:12 #252399
by Roger Fairclough
Replied by Roger Fairclough on topic Manual 4WD - 4H 4L in display?
Are you suggesting that Suzuki should build a car in the knowledge that the owner may want to fit a body lift and they should allow the necessary room around the T-box gear lever to prevent possible fouling. First off they would need to know by how much you intend to lift it.
Roger
Roger
26 Nov 2023 23:32 - 26 Nov 2023 23:36 #252406
by facade
But now Jackonlyjack has put the idea in my head, I'll check the clearance in case the lever is hitting the floor, and all the required extra effort after it initially stops moving is levering the 'box forwards on the rubbers enough to fully engage low.
I wonder if I can see the lever as it goes through the floor from underneath...
I'm only suggesting that they should be capable of cutting a hole in the floor that doesn't foul the lever when the car comes out of the factoryAre you suggesting that Suzuki should build a car in the knowledge that the owner may want to fit a body lift and they should allow the necessary room around the T-box gear lever to prevent possible fouling. First off they would need to know by how much you intend to lift it.
Roger
Last edit: 26 Nov 2023 23:36 by facade.
Time to create page: 0.158 seconds
