Manual 4WD - 4H 4L in display?
21 Nov 2023 13:29 #252268 by DrRobin
Dropping back to only one dashboard light (on a Gen 4) is a bit of a backwards step, you can't see it is in 4WD-L without looking down at the lever.
I know Suzuzki were trying to save money, but for the cost of one more LED it wouldn't have made that much difference.
I know you know if you put it in 4WD-L, but what if you parked it up one night left in 4WD-L and just forgot the next morning?
Robin
  • rogerzilla
21 Nov 2023 13:50 #252269 by rogerzilla
Replied by rogerzilla on topic Manual 4WD - 4H 4L in display?
Their research probably showed only 1% of new Jimny buyers use 4L, and only 10% use 4WD!
21 Nov 2023 13:56 #252272 by facade
On the Gen 4, when it is in Low, a multitude of Hieroglyphs light up on the dashboard as it automatically disables various driver aids.
If you try and drive off in Low, it either doesn't move at all, because the lever hasn't been hammered back into position, or it goes Vrrrrrrrrrrr! when it should be going Vrr!.
The 4WD light is just a warning to tell you not to drive on a grippy surface (and that the steering may be a bit different), it doesn't matter if it is in H or L.
21 Nov 2023 19:46 #252280 by Pondboy
Yes all the collision and Lane warming lights light up in 4WD low mode
PB
Sent from my IN2013 using Tapatalk
22 Nov 2023 11:19 - 22 Nov 2023 11:20 #252289 by yakuza
I have the 4wd-L light and still get surprised when it is in low..
So doesn't help me a lot.. would not miss it i guess except it does help some when doing fault finding on push button systems.
(But still not completely sure if is an intermittent actuator or vacuum fault.)
Last edit: 22 Nov 2023 11:20 by yakuza.
22 Nov 2023 12:27 #252291 by IICIIEII
I thought I was the only one that needs to hammer the 4L I don´t need to use it much, but when I do I am always like "oh well, here we go again". It usually takes me 2 or 3 tries!
Time to create page: 0.338 seconds
