Manual 4WD - 4H 4L in display?
21 Nov 2023 07:49 #252255
by Narge
Manual 4WD - 4H 4L in display? was created by Narge
Am I right in thinking that going in to 4WD using manual 4WD gear lever does not display 4H or 4L on the instrument display but only a 4WD light?
Many thanks
Many thanks
21 Nov 2023 08:11 #252257
by Pondboy
Replied by Pondboy on topic Re:Manual 4WD - 4H 4L in display?
My Gen 4 shows the same 4WD icon for both high and low. No other indication of being in low.
PB
Sent from my IN2013 using Tapatalk
PB
- Thank you received: 672
21 Nov 2023 08:13 #252258
Replied by DrRobin on topic Re:Manual 4WD - 4H 4L in display?
My 2011 Gen3 shows 4WD and 4WD-L when in 4WD modes. I don’t know which Jimny you have?
21 Nov 2023 09:32 #252259
by Busta
Replied by Busta on topic Manual 4WD - 4H 4L in display?
That is correct. On pre-2005 models only a 4wd light shows. There is no indication of low range other than the position of the stick.
21 Nov 2023 10:51 #252263
Replied by yakuza on topic Manual 4WD - 4H 4L in display?
Even my 1984 Jimny gen 2 got a 4wd light, so 1984 to 2004 then
2005 got the 4wd lo as well.
Mine is now blinking and flashing sometimes the 4wd light one blink or double speed, and sometimes the 4wd-L blinking with doublespeed.
Only does this when below -2.
Very annoying as it works fine at above zero and I got this large battery in the way of the solenoids and it is very cold outside.
- rogerzilla
21 Nov 2023 11:34 #252264
by rogerzilla
Replied by rogerzilla on topic Manual 4WD - 4H 4L in display?
You only need the 4L light on push-button Gen3 cars, because there is no other indication available (except a racing engine!).
Time to create page: 0.292 seconds
