Fuel line fittings for fuel tank
01 Mar 2023 10:02 #247806 by hJohn
My order has been refunded now. I don't know if I'm going to do normal fuel line or my own AN line yet. Have you made any more progress gv42?
02 Mar 2023 09:24 #247839 by hJohn
I have had a look at what I would need to solve this using AN lines.
  • 5/16" quick connect to AN6 adapter
  • 3/8" quick connect to AN6 adapter
  • AN6 steel braided hose 2 x 4 meters
  • AN6 hose end x 2
  • A couple of AN6 hose holders
  • Tools for assembling the AN lines
Is there anything that I have missed?
All of this is quite expensive from the local motorsports supplier, 200 GBP not including tools.
03 Mar 2023 16:41 #247866 by gv42
www.autosiliconehoses.com/about-us
Getting fuel hose here
Sent from my 2201116SG using Tapatalk
03 Mar 2023 16:49 #247867 by gv42
We are going with rubber fuel hose and clips, and those plastic connecters
02 Nov 2023 20:07 #251925 by hJohn
Been a while since I disassembled everything and I can't remember how it's supposed to go back together.Does anyone know how it's supposed to be connected?
I assume the unlabeled pipe from the fuel pump goes to "EVAPO PIPE", as for the other two which goes on the bigger pipe on the injector rail? "DELIVERY PIPE" or "PRESS RGLTR"
04 Nov 2023 07:07 #251943 by facade
The largest diameter is the pressure feed (delivery ) from the pump. It goes to the open end of the fuel rail.
The thinnest pipe (I think- or are there 2 thin ones?) is the vent and goes to the evap canister to trap the fumes.
The thinner than delivery is the return pipe and goes to the outlet of the regulator.
The Plan is that any surplus fuel is leaked off by the regulator (and comes out of it) to maintain pressure in the rail.
I'd imagine that the return pipe goes down into the fuel for silencing, whereas the vent is in fresh air right at the top of the tank, so if you blow into the return spigot you will hear bubbles
Time to create page: 0.957 seconds
