Fuel line fittings for fuel tank
28 Jan 2023 18:42 #247239
by hJohn
Fuel line fittings for fuel tank was created by hJohn
Hello,
My fuel lines started leaking - from above the tank. So now I have dropped the tank and removed the fuel lines but they use a special fitting that I do not know the name of.
Does anyone know what the fittings are called? Can I remake new lines with the current fittings, buy just new fittings or do I have to order completely new lines?
- Roger Fairclough
- Thank you received: 225
28 Jan 2023 21:38 #247243
by Roger Fairclough
Replied by Roger Fairclough on topic Fuel line fittings for fuel tank
pics. of the pipes would be helpful.
Roger
Roger
29 Jan 2023 08:46 - 29 Jan 2023 08:59 #247246
by hJohn
Replied by hJohn on topic Fuel line fittings for fuel tank
Which pipes after you referring to?
Are you able to see the pictures I attached? I am trying to replacing all of the lines going from the fuel tank.
Edit: I am talking about part 8 & 9 from this exploded view here partsouq.com/en/catalog/genuine/unit?c=S...id=1624&uid=63649&q=
Part numbers are 15820-81A02 and 15860-81A02.
Last edit: 29 Jan 2023 08:59 by hJohn.
29 Jan 2023 09:04 #247249
by hJohn
Replied by hJohn on topic Re:Fuel line fittings for fuel tank
Does that kit include both the fuel line and the return line? And does it go the full length to the engine?
29 Jan 2023 09:28 #247250
by gv42
Replied by gv42 on topic Re:Re:Fuel line fittings for fuel tank
It's a kit we got, came with 2 lines , both different diameters, long enough to reach the rail, in engine bay, didn't come with vent pipe, I don't think the retailer has the dual kit left, but will get you details of the bits and bobs, as it's all off the shelf items from what we can see, will find out the details in the week?
Sent from my 2201116SG using Tapatalk
- Roger Fairclough
29 Jan 2023 09:54 #247251
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Fuel line fittings for fuel tank
These bayonet style fittings may be to a basic fuel line spec. Search for "Movkzacv fuel line quick release coupler". I found the info. on Amazon. Data sheet gives dimensions so you can check with the tank fittings. About £8 each.
Roger
Roger
