Fuel line fittings for fuel tank
07 Nov 2023 05:36 #252012 by hJohn
In this video they showed two of the lines connected so I just copied that, now everything works as it should.
07 Nov 2023 14:00 #252014 by facade
Not with only 2 lines connected it won't...
If you haven't connected the return pipe, where does it go?
If it is blanked at the regulator then the regulator won't work as it can't bleed off pressure and the rail will be at the pump's maximum pressure.
Or do you mean that you actually connected all 3 pipes, taking the return from the regulator to the one that they didn't connect in the video?
That is how it should work.
