Re:Re:50mm lift - sway / role bar adjustment spacer ?
- lookonimages
- Thank you received: 65
Your opinions.
Adjustable drop links are available but there is only so much shorter you can go.
- Thank you received: 923
There's 6mm, 12mm, 25mm available now, and 38mm going into production as soon as the bar stock arrives...
Link to eBay
Dave
ZookBOB
- lookonimages
Hence my one single negative feedback
(The delivery time comment was unfair as they were shipped via eBay's Global Shipping Program!!!)
I'll have to order a bush metal loop strap (from Martin) to research and produce them for the Gen4...
Cheers,
Dave
- lookonimages
Thanks Dave.X8GGY wrote: No, they're apparently different spacing between the bolt holes...
Cheers,
Dave
Appreciate you doing this for jimny owners.
Dont read to much into that one negative comment.
Keep doing what you do. !!
- Dirtbird
- Visitor
Can I just Chime in on this? I bought this kit from Dave and its first class. I've also found Dave to be super supportive and helpful when it comes to trying to source bits and bobs locally . Cheers Dave
Cheers,
Dave
- Thank you received: 1811
- Sean65
- Visitor
- lookonimages
From my perspective it all "depends" onwhat you mean with 50mm lift.Sean65 wrote: Can i just confirm having read this thread with interest and having just fit a 50mm lift that the total removal of the ARB is accepted practice. Cheers
Spacer lift ?
Spring lift ?
Proper stronger shocks ?
It is not accepted pactice but some do it, but they know the impact of such a removal.
