Gearbox filler
08 Apr 2021 21:55 #234337
by Davemc
Replied by Davemc on topic Gearbox filler
X8GGY wrote: I use one of these with a ratchet spanner...
I’ve just used this method as well as no room for a socket set.
Definitely 10mm
09 Apr 2021 15:25 #234347
by Obarno
Replied by Obarno on topic Gearbox filler
On mine i removed the carpets, and after some careful measuring I cut a hole through the side of the gearbox tunnel and then fitted a rubber plug. It makes changing the oil much easier.
- Thank you received: 923
11 Apr 2021 10:02 #234393
Replied by X8GGY on topic Gearbox filler
I've had a look this morning... on my old X reg Jimny Boogie...
the gearbox filler is on the drivers side! LOL :lol:
Slightly different?!
11 Apr 2021 10:30 - 11 Apr 2021 17:06 #234395
In fact... about, here -
The bigger holesaw was just used to cut through the sound-deadening material, so that it could be scraped off -
Last edit: 11 Apr 2021 17:06 by X8GGY.
11 Apr 2021 17:02 - 11 Apr 2021 17:07 #234399
I then made a "lid" for it... (Using the same two hole-saws)
So that it covers the access hole -
Wider shot...
Wider shot...
Last edit: 11 Apr 2021 17:07 by X8GGY.
The following user(s) said Thank You: lookonimages
