Gearbox filler
- X8GGY
05 Apr 2021 15:11 #234263
Replied by X8GGY on topic Gearbox filler
No eBay APP ID and/or Cert ID defined in Kunena configurationI use one of these with a ratchet spanner...
05 Apr 2021 17:12 #234267
by HUN
Could you let me know if the provided dimensions have to be altered for the R7ME gearbox, please? Thanks.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic Gearbox filler
Dave,X8GGY wrote: Another member did this.... www.bigjimny.com/index.php/forum/15-loun...rkel-template#223635
something I'm going to copy... soon!
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- grumyoldjoe
Topic Author
- Elite Member
- Thank you received: 20
05 Apr 2021 19:15 #234269
by grumyoldjoe
Wine improves with age.
Replied by grumyoldjoe on topic Gearbox filler
Thanks all, will have another go.
Boogie - I have that tool but still struggle to get purchase.
Maybe at 60+ Im getting too old to be crawling underneath. Smashed me head wide open on the tow point despite the Jim being on ramps. .
BTW car is 2013 model
05 Apr 2021 21:17 - 05 Apr 2021 21:18 #234270
by Scimike
Replied by Scimike on topic Gearbox filler
I put my Jimmy on two sets of ramps when I service the gearbox etc so it's level and I have plenty of room. Drive the front up the first set then lift the rear on my jack and place the second set.
It's the best low cost option for working on the underside in my opinion and with a mechanics crawler board it's almost comfortable!!
Good luck with take two.
Last edit: 05 Apr 2021 21:18 by Scimike.
The following user(s) said Thank You: grumyoldjoe
- Thank you received: 115
06 Apr 2021 11:55 #234276
by maverick
Jalapeño, IISY?
Replied by maverick on topic Gearbox filler
Don't forget "not to make the school boy error" by removing Gearbox Oil until you have successfully remove the plug to fill it back up!!
Jalapeño, IISY?
08 Apr 2021 21:45 #234336
by Davemc
Replied by Davemc on topic Gearbox filler
I’ve just used this method as well as no room for a socket set.
Definitely 10mm.
Definitely 10mm.
Time to create page: 0.268 seconds
