Gearbox filler
- grumyoldjoe
Topic Author
- Elite Member
- Thank you received: 20
05 Apr 2021 13:02 #234255
by grumyoldjoe
Wine improves with age.
Gearbox filler was created by grumyoldjoe
Any tips/ideas help in getting access to and removing the gearbox filler plug ?
Ive tried from underneath whilst on ramps, and from top but I just cant the tool or purchase on the plug to remove it.
I have the "s" type key and also socket type key but struggling.
TIA
TIA
05 Apr 2021 13:24 - 05 Apr 2021 13:25 #234257
Replied by yakuza on topic Gearbox filler
What year / model car?
Mine was a 3/8 square so I used Just the wrench with no socket.
Last edit: 05 Apr 2021 13:25 by yakuza.
05 Apr 2021 14:21 #234259
by Scimike
Replied by Scimike on topic Gearbox filler
I do the same as Yakuza, can't recall the size, but one of my socket wrench square drive pegs just fits the plug.
Been easy for me from below on ramps. Not on the gearbox, but I did need to warm the case of the axle with a blow touch around the filler to get it out. Did not take much heat, just a warm up and the bung came out. Maybe if it's tight on the gearbox try this. As it's alloy just warm it slightly, it will expand enough.
Mike
Mike
- X8GGY
05 Apr 2021 14:25 #234260
Replied by X8GGY on topic Gearbox filler
Another member did this....
www.bigjimny.com/index.php/forum/15-loun...rkel-template#223635
something I'm going to copy... soon!
05 Apr 2021 14:37 #234261
by fordem
Replied by fordem on topic Gearbox filler
Be VERY careful with this approach - it's 10mm square, NOT 3/8 inch and at some point the use of 3/8 inch square drive will slip & round out the hole.yakuza wrote: What year / model car?
05 Apr 2021 14:46 #234262
Agree, tanks for arresting me. But there is almost no room for the wrench plus socket.
I make sure not to overtighten.
Time to create page: 0.360 seconds
