Re:JB74 OBD2 connection
- Thank you received: 370
I have voltage on my Gen 3 and other car, I don't think you need a specific PID. If you can't find it I will have to have a look on my car.
- stuart
- Visitor
PNP, could you let us know which terminals on your OBD socket are wired?PNP wrote: TorquePro with a Veepeak b/tooth connected fine on JB74W, looking for a battery voltage meter PID as it is not indicating?
- BlueMethJimny
- Visitor
Sorry no idea about the Torque Pro, I dont have a reader.stuart wrote: Excellent work Twisticles!! I'll be ordering one of those.
I wonder if the Torque Pro app is not compatible with ISO 15765-4 either?
https://imgur.com/KSd7E7f
Also, I bought one of these too , which is just a digital display reflected up to the windscreen. I didnt use the included plastic that you're supposed to stick where it reflects, so I get a bit of ghosting where it reflects on both the inside and outside surfaces of the windscreen. But I can live with that to have the speed so clearly in my peripheral vision.
Great little gadget for $12!
I purchased and tried both of the devices that worked for you, but unfortunately neither worked for me. The more expensive one only seem to have 'worked' because it has a GPS mode. But it isn't really using the OBDII connection.
I also tried my luck with the Autool X60 hoping it will be like the guy in Italy in the video, but like OP it didn't work for me too. This has become very frustrating. Why Suzuki made this so difficult for their customers is beyond me.
- BlueMethJimny
- Visitor
Did you have any luck with any HUD that works with JB74W? I'm based in the Philippines and I suspect we have the same 'issue'.
- MarQsz
- Visitor
I am a proud owner of new Jimny HJ B74B (two seater with cargo space).
Yesterday I obtained from Amazon Autool X60 www.amazon.pl/dp/B07L8RPLCG and connected today. After the connection the device tried all protocols and displayed "no connection". I restarted the machine and this time it connected at once.
It is working correctly, displays the coolant temperature I wanted to observe.
- Thank you received: 82
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
