BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:JB74 OBD2 connection
21 Dec 2020 13:24 #231083 by Bill Portland
I see that the latest update of the SZ viewer app now has a TPMS tab. I must plug it in and see what it does.
21 Dec 2020 16:13 #231084 by mlines
Replied by mlines on topic JB74 OBD2 connection
Looking at the Circuit diagrams, for the UK it appears to be
Pin 1 - (Grey) - +12Volts
Pin 3 - (White) - CAN
Pin 11 - (Blue) - CAN
Pin 12 - (Black) - Ground
Pin 13 - (Black) - Ground
Now those of you familiar with OBD2 wiring will be intrigued by the numbers as they should be
Pin 16 - 12v
Pin 6 - CAN
Pin 14 - CAN
Pin 4 - Ground
Pin 5 - Ground.
However if you count the pins backwards then the numbers match so I think either Suzuki or the OBD2 specification looks at the reverse of the connector.
26 Dec 2020 17:06 #231208 by DrRobin
Replied by DrRobin on topic JB74 OBD2 connection
This is the OBD2 connector on my Gen3 from 2011, no CAN bus on this variant.
The dongles/obd reader I have has the pin numbers marked on treating face, but they don’t seem to be on the socket (attached to the car) so PIN numbers must be from the plug end.
26 Dec 2020 20:18 #231216 by mlines
Replied by mlines on topic Re:JB74 OBD2 connection
By coincidence I was playing with code reading today
The following user(s) said Thank You: Bill Portland
  • Twisticles
  • Visitor
  • Visitor
21 Jan 2021 05:02 #232021 by Twisticles
Replied by Twisticles on topic JB74 OBD2 connection
Did you ever figure this out?
I'm interested in the Autool or similar.
HK version Jimny here!
  • stuart
  • Visitor
  • Visitor
02 Feb 2021 01:46 #232416 by stuart
Replied by stuart on topic JB74 OBD2 connection
Unfortunatly not, I'm still very interested in finding a solution though!
  • Twisticles
  • Visitor
  • Visitor
02 Feb 2021 08:43 #232421 by Twisticles
OK so I did some work on this.
I started with Martin's pin-out:
Pin 16 - 12v
Pin 6 - CAN
Pin 14 - CAN
Pin 4 - Ground
Pin 5 - Ground.
Which led to me this site , where it looks like that pin-out is used by ISO 15765-4/SAE J2480 (CAN) protocol.
That may or may not be accurate, but I decided to set off and look for an OBD2 unit that is capable of that protocol.
I couldn't find anything on the Autool X60 that indicated it was compatible with the ISO 15765-4 protocol.  But I did find this unit , at twice the price of the Autool which specifies that protocol.
I ordered, plugged in and it worked straight off the bat.  Note:  I have a JB74W in Hong Kong.
I do like having a digital speedo for my aging eyes!  No idea why Suzuki missed that out of the dashboard display.
  • stuart
  • Visitor
  • Visitor
19 Feb 2021 12:15 #232990 by stuart
Excellent work Twisticles!!  I'll be ordering one of those.
I wonder if the Torque Pro app is not compatible with ISO 15765-4 either?
  • Twisticles
  • Visitor
  • Visitor
20 Feb 2021 11:25 - 20 Feb 2021 11:34 #233038 by Twisticles
stuart wrote: Excellent work Twisticles!!  I'll be ordering one of those.
Sorry no idea about the Torque Pro, I dont have a reader.
https://imgur.com/KSd7E7f
Also, I bought one of these too , which is just a digital display reflected up to the windscreen.  I didnt use the included plastic that you're supposed to stick where it reflects, so I get a bit of ghosting where it reflects on both the inside and outside surfaces of the windscreen.  But I can live with that to have the speed so clearly in my peripheral vision.
Great little gadget for $12!
Last edit: 20 Feb 2021 11:34 by Twisticles.
  • stuart
  • Visitor
  • Visitor
24 Feb 2021 02:57 #233185 by stuart
Do you have a photo of the other unit in place?
24 Feb 2021 05:39 #233189 by crash486
Replied by crash486 on topic Re:JB74 OBD2 connection
I run torque pro on a Android tablet.
Australian Jimny so no idea if they are different.
crash486 JB74W
24 Feb 2021 09:35 #233196 by PNP
Replied by PNP on topic Re:JB74 OBD2 connection
TorquePro with a Veepeak b/tooth connected fine on JB74W, looking for a battery voltage meter PID as it is not indicating?
Time to create page: 0.171 seconds
Powered by Kunena Forum
