G16 Swap with Baleno harness and ECU, Tach and Speedo NC
- Jim Jim
- Visitor
I have been working on the completion of my G13 to G16 swap using the Baleno harness and ECU.
The swap was successful and the engine runs perfectly, however I cant get the tachometer nor the ODO to work using the 99 Jimny instrument cluster.
The digital display section on the Speedometer witch has the milage is not working, its blank, I have not been able to drive the Jimny as yet to see if the speedometer itself is registering speed.
I have been reading the variable speed sensor, VSS does not work with the Sierra swap but I see no mention about the Jimny, would anyone know if this is the case with the Jimny?
Is the tach input signal and VSS signal for the 99 Jimny different from that of the 2000 Baleno? I am getting a tach signal right up to the tach but
the tach is not working.
Thanks Mates.
I will post pics in my build thread when I have everything working and sorted out.
- Thank you received: 1764
I know in an M series the signal to the dash cluster for the speedo and tach are physically wired to the ECU (along with almost everything else on the dash cluster), so would assume a G series to be the same. That means the cluster must have other connections for earthing or power supply, dash lights, etc.
- Jim Jim
- Visitor
Everything worked perfectly well on the G13BB before the swap.
- Jim Jim
- Visitor
The entire cluster worked flawlessly. I am getting instrument cluster lights, oil, charge, hand brake and check engine lights.
We are getting power to the cluster, fed by a black wire with a white stripe. There are signals tied into the 4WD module, all checked out OK.
- Jim Jim
- Visitor
- Jim Jim
- Visitor
I was seeking confirmation the input signals are the same so I wont be wasting my time trouble shooting.
I do have a feeling I am missing a ground or another splice somewhere. We are getting power to the cluster for sure and the RPM input to the tachometer is certain, but it's not reading RPM. The tach input is the same as the Jimny, being fed by one of the coil packs, so that should at least work.
Thanks for all the replies Mates.
- Jim Jim
- Visitor
Lambert wrote: Have you tried running the motor with the Jimny ecu? As I understand it the swap should not need a donor ecu?
I dont think that will work. If the ECU's were interchangeable there would have been no need to swap harnesses.
Cheers Mate.
- Jim Jim
- Visitor
Lambert wrote: To the best of my knowledge there isn't. As far as I am aware, having not done this myself, the only difference between the two is the displacement of the blocks, everything else like ancillaries being retained?
The ECU is not not interchangeable without its respective pinout modification on the loom. I can't plug in the G13 ECU since I have spliced in the Baleno loom and using the Baleno ECU.
Yes the head is basically the same but some mods have to be made to use the G16 block which I did.
I will post pics later of what I did and how I made it a bit simpler. Getting the cluster to work is my last hurdle, the engine runs perfectly well.
Cheers.
- Thank you received: 333
The cluster and ECU signals wiring is the problem I guess.
There is a wiring diagram for the cluster in the Field Service Manual if yuo got that, and for the ECU connections. Have you found the tacho signal on any of those?
