Forum
Suzuki Jimny
Jimny Technical
Engine oil leak !
BigJimnyMeet 2024
Engine oil leak !
M-B-E
Topic Author
Visitor
25 Jul 2020 22:23 #225657
by M-B-E
Sounds like I’m on the right track then !
how much of a job is it to change ?
Iv never taken a timing chain off before, I assume it’s behind that?
Also is there anything I should replace along the way? If I’m going in that far
Thanks
Lambert
Offline
Moderator
The quickest Jimny in Harrogate...(that I own)
Thank you received: 1761
26 Jul 2020 06:15 #225672
I didn't do it as it was the garages responsibility but as I understand it you "just " need to remove the main crankshaft drive pulley and the seal is accessed. I say just because it is very likely that the crankshaft bolt is going to offer significant resistance. It is going to help to remove the radiator to prevent damage and improve access it is also going to help to have a heavy impact wrench gun. The problem is that the bolt has an integral flange that over time rusts itself to the pulley which combined with the bolt being torqued to FT makes life difficult. Some people have had to resort to the angry grinder to cut the flange off and have a chance.
M-B-E
Topic Author
Visitor
27 Jul 2020 17:39 #225753
by M-B-E
Hmm yeah I’m always very sceptical about these jobs that sound so easy.
My radiator could do with being replaced so I might do them at the same time, (doesn’t overheat, just looks like it’s been attacked by a shark)
I’ll have a look at some point and have a little think
Thank you!
Your wisdom is appreciated
Forum
Suzuki Jimny
Jimny Technical
Engine oil leak !
Time to create page: 0.062 seconds
