BigJimnyMeet 2024
Suspension Banging
- Thank you received: 332
18 Feb 2020 07:16 #218692
Especially with a tow bar fitted, then it can get very tight.
You can also undo the spare wheel from the rear door and see if the mount there is ok, or if the sound is gone when the wheel is gone.
Have heard very bad noises from cars with broken or worn out hinges but not sure if I seen or heard it on a jimny.
Replied by yakuza on topic Suspension Banging
kirkynut wrote:
The back box is the tightest fitting part of the exhaust.
18 Feb 2020 08:01 #218693
Remember the exhaust can extend a half inch or so when hot from the heat expansion. Most of this will be the back box moving aft.
24 Feb 2020 08:12 #218989
by kirkynut
Replied by kirkynut on topic Suspension Banging
Have you got to the bottom of this yet?
Have we helped you?
What was it?
Have we helped you?
What was it?
25 Feb 2020 13:11 #219051
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic Suspension Banging
check the body mountings where it is bolted to the chassis if rusted it can snatch and only notised on bumps
- vinn3h
- Visitor
25 Feb 2020 21:56 #219084
by vinn3h
Replied by vinn3h on topic Suspension Banging
Hey guys sorry I have been slow, got pulled into something. So
I have no tow bar installed
I have bounced on the back - makes no noise
the rear door is in good condition as is the rubber seal
have looked under it shocks and springs seem ok
There is movement in the backbox but if i give it a good shake about it still does not hit anything. How much movement is normal?
- Thank you received: 225
26 Feb 2020 02:25 - 26 Feb 2020 05:22 #219090
by zukebob
Quite a bit. That was what I was focused on when I had a similar issue. Mine turned out being a loose upper shock mount. You should still hear the noise if you are making the rear move up and down so I doubt the shock mounting is your problem. Easy enough to check the shock fasteners by yourself though.
Replied by zukebob on topic Suspension Banging
vinn3h wrote: There is movement in the backbox but if i give it a good shake about it still does not hit anything. How much movement is normal?
Last edit: 26 Feb 2020 05:22 by zukebob.
Time to create page: 0.137 seconds
