IT WONT START
- gilburton
01 Apr 2016 09:25 #164731
by gilburton
Replied by gilburton on topic IT WONT START
A few years back we had a Nissan Micra and while on holiday one night I couldn't park where I wanted to in the car park so later on I came out and moved it just a few yards.
Next morning it wouldn't start so I had to call out the AA.
He said we have had a few of these and pulled the fuse on the injection system and the car started virtually straight away.
He ran it until the surplus fuel had gone and then replaced the fuse.
After that I made sure I never shut it off after a few seconds.
That's the problem with injection systems you can't clear it by flooring the throttle (as in carbs) it just gives more fuel.
- littletriple
01 Apr 2016 09:46 #164733
by littletriple
Replied by littletriple on topic IT WONT START
Hi
thanks for that, exactly what happenned to us!! The night before I turned the car around (it was cold) & parked, it would have been running for less than a minute & next morning it wouldnt fire up. With hindsight our repeated attempts would simply made it worse & we had to get it recovered to the garage. They managed to get it going & drove it onto the recovery truck :blush: Flooded with no other fault is the diagnosis & they also said its quite a common thing on all cars.
So what about the over rich mixture on start up & high idle when cold? Normal?
- Paterson
01 Apr 2016 16:29 #164745
by Paterson
Replied by Paterson on topic IT WONT START
mines deffinetly not a flooding issue there no fuel getting to the rail to flood it with
- mickt
03 Apr 2016 09:08 #164798
by mickt
Replied by mickt on topic IT WONT START
The engine "over fuels" when it is cold.( in lieu of choke) It senses this through the output of the water coolant sensor. Maybe that is not working correctly and the ecu is over fuelling in response when the water is hot!
- littletriple
04 Apr 2016 13:16 #164841
by littletriple
thanks for that! I guessed there would be a sensor somewhere to monitor engine temp. Do you know where it is?
mickt wrote: The engine "over fuels" when it is cold.( in lieu of choke) It senses this through the output of the water coolant sensor. Maybe that is not working correctly and the ecu is over fuelling in response when the water is hot!
- mickt
04 Apr 2016 18:36 - 04 Apr 2016 18:58 #164865
by mickt
Having re read your initial entry then yes it does get extra fuel when cold and the engine revs go up accordingly. As the engine warms up and the water temp in the block goes up then the ecu trims accordingly. You should hear the revs dropping to if you are stationary and throttle is closed. As said earlier opening the throttle just dumps more fuel in and can flood the engine. What engine has yous got. G13bb or m13a?
The G13BB is on the intake manifold at the front and the M13A is at the rear of the head on the left looking from the front.
Last edit: 04 Apr 2016 18:58 by mickt. Reason: amendment to the text
Time to create page: 0.101 seconds
