IT WONT START
  • Paterson
27 Mar 2016 19:02 #164461 by Paterson
Replied by Paterson on topic IT WONT START
Ok thanks I think I'm just going to order cam and crankshaft sensors my friend seems to have disappeared off the face of the planet with the code reader anyway ....
  • littletriple
30 Mar 2016 18:41 #164660 by littletriple
Replied by littletriple on topic IT WONT START
Interested in what you find. Ours has just developed a similar problem. It cranks but won't fire. I can smell petrol at the exhaust so suspect there's no sparks. It was fine in the evening but wouldn't start the next morning. All suggestions welcome :sick: .
  • Paterson
30 Mar 2016 21:25 #164667 by Paterson
I'm still none the wiser on mine I've replaced the cam and crankshaft sensors Still the same symptom ..cranks doesnt start no fuel at the rail and no spark .
31 Mar 2016 06:07 - 31 Mar 2016 06:11 #164679 by skywalker65
Replied by skywalker65 on topic IT WONT START
Start with basic checks , power to the coils and fuel pump ? Can you hear any clicking from the injectors. Could be an Ecu failure but would think that's pretty rare. Sounds like a power supply issue. Someone had a similar issue on here and he traced it to.a badly corroded wire from the fuse relay box area. Had to untape the harness slightly to find it as water he got in
If in doubt ...... Flat out ??
Last edit: 31 Mar 2016 06:11 by skywalker65.
  • Paterson
31 Mar 2016 19:34 #164710 by Paterson
This is my last resort I'll remove all the loom tape and check everything for continuity but I'll have to source a wiring diagram of what does what
  • littletriple
01 Apr 2016 07:33 #164726 by littletriple
well, embarrassingly it seems ours was just flooded.:blush: Didn't realise that was even possible with "modern" injected engines. :blink:
But this raises another question. I have always felt it runs way rich on cold starts & idles at near 3000 until warm when all returns to normal. The garage also reckon it is over fuelling when cold which could partly explain the flooding. Is this usual & does anyone know if it can it be adjusted?
Time to create page: 0.214 seconds
