IT WONT START
- littletriple
05 Apr 2016 08:50 #164886
by littletriple
Replied by littletriple on topic IT WONT START
Hi mickt,
Yes, your description is exactly what we get. When cold the engine will idle at around 3000. This falls as the engine warms up & eventually returns to normal. It seems very high to me & would support the theory of a faulty sensor also resulting in an over rich mixture too. What is the expected idle speed when cold (0 degrees)?
Thanks for the sensor position info, this is the m13a.
- Paterson
05 Apr 2016 16:33 #164908
by Paterson
Replied by Paterson on topic IT WONT START
seems its turned into problems about other jimnys issues than the one I am having with mine
- mickt
05 Apr 2016 16:57 - 05 Apr 2016 16:58 #164909
by mickt
Replied by mickt on topic IT WONT START
It happens all the time unfortunately. Better if people just started their own threads but perhaps its the sign of the times! It is not only this forum that it happens. Others do too!
Anyway any progress on your defect yet
Last edit: 05 Apr 2016 16:58 by mickt. Reason: amendment to the text to clarify
- Paterson
05 Apr 2016 17:30 #164911
by Paterson
solved my issue is was a break in the wiring loom blue wire to the main relay in the engine bay .
as soon as i repaired this i had the engine managment light and imobiliser light all showing as they should with ignition on and i could read the ecu with a code reader .seems that wire was quiet an important one haha
- littletriple
05 Apr 2016 20:35 - 05 Apr 2016 20:36 #164934
by littletriple
Point taken. sorry about that, :blush: Glad you found your problem.
Paterson wrote: seems its turned into problems about other jimnys issues than the one I am having with mine
Last edit: 05 Apr 2016 20:36 by littletriple.
Time to create page: 0.166 seconds
