IT WONT START
- Paterson
25 Mar 2016 22:17 #164361
by Paterson
IT WONT START was created by Paterson
Hi my poor jimny will not start
I had been out last Sunday off roading local lanes nothing to drastic few wet muddy bits on way home I noticed steering/suspension had developed an issue couldn't hold it in a straight line thought I'd take it to my local jet wash give it a blast off so it was clean to look over everything to try find what was causing this .
So Monday
Moved car onto the drive found bushes on the radius arms had seen better days and a track rod end so I left the car where it was
Today (Friday) fitted all the new parts as planned new poly bushes and the trackrod also spotted it needed new pads so dashed out to get some ....fitted everything all done drop the car back on its wheels to go for a test drive
The problem
Car turns over but doesn't fire
so I started with the basics unplugged every connector i could find in the engine bay all look nice and dry inside sprayed with quick mist of wd40 then clicked back together tried turning it over same again cranks doesn't fire
Next on the list checked all the wiring for damage can't see anything that would have been caught or snagged when lowering the axle to change the bushes
Checked the fuses in the engine bay on the drivers side
Checked fuses under the steering column
All fine
Checked for a spark removed a plug put it in the ht lead and cranked no spark the plug was dry so I checked for fuel at the fuel rail
Removed hose cranked it again nothing
After much reading on the internet found the fuel pump relay location removed relay checked it can hear it clicking .
I then put 12 v Into the loom I had fuel instantly at the rail so that sais pumps good
Now I'm out of ideas I've searched the internet high and low but no luck on finding a match to my car
I did find a few posts about imobilizer faults I've only owned the car a few weeks so I'm unfamiliar with the sequence on the dash lights when I turn on the ignition I don't have a car with a padlock for the imobilizer shown or an engine managment light
Help!!!
Thanks
So Monday
The problem
All fine
Help!!!
Thanks
25 Mar 2016 22:54 #164364
by j999pre
Grey pick up Jimny
Replied by j999pre on topic IT WONT START
Check the wiring to both relays. Look for corroded wires maybe
Grey pick up Jimny
- Paterson
26 Mar 2016 14:39 #164390
by Paterson
Replied by Paterson on topic IT WONT START
Today I've physicals checked all the fuses not just with the teat light checked wiring to the relays all looks good.. Took the dials out to check if somebody had removed the bulbs for the immobiliser swapped them all about I don't seem to have the light on the dash I keep reading about.... I have checked coil around key..... I have grey key non central locking
- skywalker65
- Premium Member
- Thank you received: 20
27 Mar 2016 07:16 #164408
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic IT WONT START
No spark and no fuel suggests crank sensor. Most injection systems rely on the engine Ecu receiving a signal from the sensor to start everything going
- Paterson
27 Mar 2016 08:18 #164409
by Paterson
Ok thankyou I'm hopefully I'm borrowing a decent code reader off of a friend to try and check live data see if it's getting a signal ....I did notice last thing yesterday the rev counter doesn't move at all when I'm cranking so this would make sense
- gusthegorilla
27 Mar 2016 08:27 #164410
by gusthegorilla
Replied by gusthegorilla on topic IT WONT START
Be aware also that a crank sensor fault has a habit of NOT showing up on the fault reader. .....I was caught out by this small but significant fact, and wasted days..... :pinch:
Time to create page: 0.271 seconds
