BigJimnyMeet 2024
Severe vibration 1800 to 2200 rpm
- Dave Biezen
- Visitor
25 Feb 2016 12:39 #162982
by Dave Biezen
Replied by Dave Biezen on topic Re:Severe vibration 1800 to 2200 rpm
Did you find out the problem?
Same shit in my car,....everything is vibrating....something will break ð³
- Dave Biezen
- Visitor
25 Feb 2016 12:41 #162983
by Dave Biezen
Anyone found a solution for this anoying problem?
- Thank you received: 653
25 Feb 2016 13:44 #162985
Replied by jackonlyjack on topic Re:Severe vibration 1800 to 2200 rpm
does it vibrate more on corners ?
mine used to vibrate like hell on right handers
turned out it was rear engine mount on the gearbox
fitted new one vibration gone
Jack
Jack
The following user(s) said Thank You: Dave Biezen
- Varicapp
- Visitor
25 Feb 2016 14:06 #162986
by Varicapp
Replied by Varicapp on topic Re:Severe vibration 1800 to 2200 rpm
All mounting new. The problem is not exactly in them
- Dave Biezen
- Visitor
25 Feb 2016 14:12 #162987
by Dave Biezen
All mountings are new here also and i lined the engine and gearbox out with no result,....this is the first time my brains can't figure out how to fix it ðº
- Varicapp
- Visitor
25 Feb 2016 14:16 #162988
by Varicapp
I have two cars a year. One problem is, all right in the second car.
- Dave Biezen
- Visitor
25 Feb 2016 14:28 #162989
by Dave Biezen
The problem started with me changing the clutch,...2 years back,...i thought that i could have screwed the new plates because the transmission difn't fit easy the first time.
So new clutch kit again,...no result.
I even bought a complete gearbox all the shafts transfer box and diff to rule things out. No
As far as i can tell there is nothing wrong with the flywheel...it seems in balance and turns smooth....
- skywalker65
- Premium Member
- Thank you received: 20
28 Feb 2016 08:06 - 28 Feb 2016 08:07 #163074
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Severe vibration 1800 to 2200 rpm
Not seen the Suzuki clutch but I know on our Bmw bikes that they have paint marks on the clutch components as they're all indicators of balance points and these have to be staggered at 120 degree intervals on assembly.
Can't remember at this point in time wether Jimnys have a split prop shaft. The thinking behind that is are the uj's at either end in line with each other ?
Clutch plate alignment another possibility.
Go back to basics and start with what you have changed.
Was a proper spline grease for example used on the clutch plate / gearbox splines ? Gearbox input shaft splines worn ?
Anti seize greases such as coppa slip can't be used as their construction can exacerbate spline wear
Last edit: 28 Feb 2016 08:07 by skywalker65.
- Dave Biezen
- Visitor
28 Feb 2016 09:14 #163077
by Dave Biezen
Replied by Dave Biezen on topic Severe vibration 1800 to 2200 rpm
Thanks,
I will just do that,...start all over again.
I found a big resonance source when I knocked the left rear coil spring. The rubber seat was worn and strange enough it was filled with water because the bottom had no hole in it as it has on the right side.
I need to replace those rubber seats anyway. But for now i rubbed them in with red rubber grease.
The most terrible noise is gone now but the fibration remains.
So indeed back to start
- Dave Biezen
- Visitor
28 Feb 2016 09:17 #163078
by Dave Biezen
Btw,....it doesn't say anything about marks but i made sure that the pressure plate was in the easiest fitting position
- 1066Boy
- Visitor
01 Mar 2016 17:48 #163211
by 1066Boy
Replied by 1066Boy on topic Severe vibration 1800 to 2200 rpm
I have read this post through with interest. Mine has a slight vibration below 2000 rpm.
Its not as bad as some describe on here but its more engine noise and a little vibration in mine.
It only happens in 3,4 & 5 gear with half throttle or more. I can sit at 1800 rpm in any gear if on a light
throttle. It has always been the same and just put it down to me asking too much of a small engine
when the revs are low so not producing enough torque to match the load placed upon it.
- wombat
- Visitor
01 Mar 2016 18:47 #163219
by wombat
Replied by wombat on topic Severe vibration 1800 to 2200 rpm
As the problem started after a clutch change i would be looking at propshaft faults/ alignment or a faulty clutch
Time to create page: 0.119 seconds
