Difficulty engaging first gear.
- Greensuzks
- Visitor
01 Jan 2013 10:26 #56763
by Greensuzks
Replied by Greensuzks on topic Difficulty engaging first gear.
I replaced my clutch disc and pressure but same problem with my first gear. Now, I have to leave with it.
22 Jan 2013 22:56 #59214
by BAZZOOK
Replied by BAZZOOK on topic Difficulty engaging first gear.
before selecting 1st or reverse put it into 2nd gear. This slows down the spinning gears and makes it easier to get 1 st.
11 Oct 2022 00:44 #245378
by chronicle
Replied by chronicle on topic Difficulty engaging first gear.
Hi All,
Bumping this thread. I have a JB43 manual and have trouble engaging first gear at the start of the morning.
I normally put it on other gears first to make it go to first.
When the engine/transmission warms up, I can shift to it without problems.
Do you reckon changing to the gear oil would solve this?
PS: i know that Jimny's manual transmission itself is finicky at best. I checked the shifter bushings and are all in order.
- Thank you received: 1627
11 Oct 2022 03:24 #245379
Replied by Lambert on topic Difficulty engaging first gear.
Years ago I once used a gl4/5 combination oil in my manual and it made changes between gears difficult. Swapping to the preferred gl4 solved it. However I only had problems once it was up to temperature. Gear oil is cheap so as a first things first it makes sense to swap it.
11 Oct 2022 04:13 #245380
by chronicle
Thanks mate. My issue is the complete opposite of yours. Will look into changing the oil first.
- Thank you received: 66
11 Oct 2022 07:14 #245382
by lightning
Replied by lightning on topic Difficulty engaging first gear.
l wouldn't normally engage first gear while a vehicle is moving.
My Defender has never liked first gear when it's not stationary.
- Thank you received: 585
11 Oct 2022 19:18 - 11 Oct 2022 19:24 #245403
Replied by jackonlyjack on topic Difficulty engaging first gear.
Redline MT90
New rear engine mount
New bobbins on gear box selector plate
All of the above helped mine
Also do not try to engage 1st when moving
These are poly Austin mini exhaust bobbins
You can use rubber version rubber lasted for around 3 years
Last edit: 11 Oct 2022 19:24 by jackonlyjack.
