Fog light wiring???
21 Apr 2010 09:24 #3203
Replied by mlines on topic Re:Fog light wiring???
Sorry, I forgot about this, I have the wiring diagram for this model at home. I am at work at present so will try and remember it later.
- coptleigh
- Visitor
21 Apr 2010 09:25 #3204
by coptleigh
Replied by coptleigh on topic Re:Fog light wiring???
Martin, just out of curiosity, is that a RAF uniform you are wearing???
Alan
Alan
21 Apr 2010 09:32 #3205
Yes, it was the only picture I had to hand when creating the Avatar. I am in the RAFVRT
By the way, the manual for your model says it does not have front fog lights and no wiring is shown. I have a manual for a later one that does and will send you over info on both
- coptleigh
- Visitor
21 Apr 2010 09:36 #3206
by coptleigh
Thanks for that,
Coincidence, my son is in the ATC(36sqd Hetton le Hole) and was promoted to corporal last night after attending a JNCO course at RAF Boulmer at the weekend,very proud of him,,, Small world!!
Cheers
Alan
Cheers
Alan
21 Apr 2010 09:37 #3207
- coptleigh
- Visitor
22 Apr 2010 16:32 - 22 Apr 2010 16:35 #3213
by coptleigh
Martin,
any luck on the wiring diagram front? as may have a go at wiring them up this weekend!) This email address is being protected from spambots. You need JavaScript enabled to view it.)
Cheers
Alan
Cheers
Alan
Last edit: 22 Apr 2010 16:35 by coptleigh.
22 Apr 2010 17:08 #3214
Alan
You should have a pair of emails
- coptleigh
- Visitor
23 Apr 2010 09:31 #3216
by coptleigh
Martin,
Received with thanks,
Cheers
Alan
Cheers
Alan
- coptleigh
- Visitor
25 Apr 2010 18:08 - 25 Apr 2010 18:09 #3240
by coptleigh
Right,Fog lamps wired up and working, used the 3rd party wiring/relay etc, looked to be too much of a hassle to try and utilised the loom, if the connectors were there??
BUT, can anyone tell me if I use the original suzuki switch, which pins to use on it!!
The switch with the kit uses 3 wires, one is an earth, one from the relay, and the last which links into the dipped beam circuit,the suzuki switch has five pins, , I'm afraid looking at the wiring diagram is a bit beyond me to fathom where this is concerned.
Cheers
Alan
Cheers
Alan
Last edit: 25 Apr 2010 18:09 by coptleigh.
25 Apr 2010 18:34 #3241
The switch is shown in the second manual I sent over.
Pins 5 and 6 are the +ve feed, these are wired to the lighting circuit in the Jimny as you are not allowed to have the fog lights on without having the lights on. Pin 6 is just the feed to illuminate the switch, pin 5 is the power that goes through to the fog lamps.
Pins 1 and 2 are earths.
Pin 4 is the output to the fog lamp relay.
- coptleigh
- Visitor
26 Apr 2010 20:43 #3257
by coptleigh
Martin,
sorry to be a pain, but could you tell me, if I have only 3 wires from the 3rd party wiring I have,
1. from the relay
2. from the sidelight circuit
3. an earth
which pins on the suzuki switch do I use, does this make sense??
Cheers
Alan
1. from the relay
3. an earth
Cheers
Alan
27 Apr 2010 06:06 #3261
Alan, Its pretty straight forward.
1. From relay >> Pin 4
2. From sidelight circuit >> Pins 5 and 6 (connect to BOTH)
3. Earth >> Pins 1 and 2 (connect to BOTH)
Time to create page: 0.141 seconds
