BigJimnyMeet 2024
How to increase steering wheel reaction?
- THOR
- Visitor
03 May 2011 19:04 #15827
by THOR
How to increase steering wheel reaction? was created by THOR
Hi guys...anybody knows how to increase the steering wheel reaction?
My steering feels very light and there is a delay when i turn the steering wheel before the wheel turns where i want it to go.
I experienced this after a suspension lift. I already installed a steering stabilizer for vibrations and shimmy.
Additionally, I hear a clacking sound when I turn the steering wheel initially, then the sound would be gone...
- Thank you received: 116
03 May 2011 19:26 #15828
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: How to increase steering wheel reaction?
sounds like you need Caster Corrected Radius Arms or Bushes!
Jalapeño, IISY?
- THOR
- Visitor
03 May 2011 19:55 #15831
by THOR
Replied by THOR on topic Re: How to increase steering wheel reaction?
hi maverick thanks for the reply...
recently i had my jimny checked for wheel alignment, and they said that my caster and camber alignments are ok (toe needs a little adjustment).
do i still need a caster correction arms and bushes?
- THOR
- Visitor
03 May 2011 20:04 #15833
by THOR
oh by the way, i did not install an adjustable panhard rod...i'm still using the stock.
So my axle is a bit off-centered and out to the left a bit...
can this cause the problem with my steering (including the clacking sound)?
- Thank you received: 584
04 May 2011 03:49 #15836
by facade
Replied by facade on topic Re: How to increase steering wheel reaction?
A cracking sound is most likely dry kingpin bearings.
A knock is play in a steering joint.
To get more self centring reaction you need more caster angle.
Having the axle out of line will make the car crab and steer a bit odd, as well as moving the wheel off centre.
- THOR
- Visitor
04 May 2011 04:08 #15837
by THOR
hi facade...
so i need to lubricate the kingpin bearings?
how do i correct a play in the steering joint?
I guess i really have to install an adjustable panhard rod, because the steering sometimes is a bit odd..as you mentioned sometimes "crab-like"..
i think i will install the caster correction bushes later, as i don't need self-centering reaction from my steering too much...
sorry, i'm such a newbie at this...
- THOR
- Visitor
04 May 2011 06:12 #15844
by THOR
hi guys...
regarding the clacking sound...i noticed that the i hear the sound and feel it at the steering wheel near the end of the steering action (both left and right turns)...this means that when i'm steering left or right and nearing the point when i could not steer anymore, i hear the clacking sound.
a mechanic said that the problem is coming from the tie rod. He said that when i had a suspension lift, this created stress on the tie rod. I took some fotos so u guys could have a look...
do i need to put a spacer on the tie rod to radius arm joint?
[attachment:1]C:\fakepath\tie rod to radius arm.JPG[/attachment]
[attachment:2]C:\fakepath\tie rod to right wheel.JPG[/attachment]
- THOR
- Visitor
04 May 2011 06:26 #15846
by THOR
hi guys...
a mechanic said that the problem is coming from the tie rod. He said that when i had a suspension lift, this created stress on the tie rod. I took some fotos so u guys could have a look, but i couldn't post them here (i don't know why?? file too big?)...
04 May 2011 06:59 #15848
Replied by mlines on topic Re: How to increase steering wheel reaction?
The clacking sound sounds to me like either a worn CV joint clicking or a tyre rubbing somewhere.
You need to reduce the size of the photographs otherwise they will not upload.
- THOR
- Visitor
04 May 2011 07:19 #15849
by THOR
thanks Martin...what is the size limit for the fotos?
my jimny is 2010 model so it is just a few months old...the CV(?) could not be worn.
i'm pretty sure it's not the tyres rubbing...
- Thank you received: 210
04 May 2011 07:40 #15850
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: How to increase steering wheel reaction?
I set my camera on 3M or l use the blog setting to reduce the size.
2002 JLX Soft Top
- THOR
- Visitor
04 May 2011 09:09 #15851
by THOR
was able to reduce size of photos thru Picasa...here they are:
i hope you guys can help....
Attachment tierodtoradiusarm.JPG not found
Attachment tierodtorightwheel.JPG not found
Time to create page: 0.126 seconds
