sj free wheeling hubs onto a jimny
21 Nov 2009 14:24 #1496
by Garry
Replied by Garry on topic Re:sj free wheeling hubs onto a jimny
thanks martin,
are the bolt sleeves really needed? reason i ask is i got my hubs from ebay without the bolts, all i have is the bolts that are holding the vacume hubs on
22 Nov 2009 16:53 - 24 Nov 2009 07:16 #1501
Replied by mlines on topic Re:sj free wheeling hubs onto a jimny
Garry,
I think they probably are needed.
You could buy some Countersunk head bolts such as these..
CLICK HERE
But I would think that the angle of the countersink is not enough. I also think the cone washer helps stop the bolt undoing on its own (due to the rotation of the wheel)
The cone Washers are part number:
43841-80000 from Suzuki
42323-60010 from Toyota.
They are really really expensive from here
www.marlincrawler.com/axle/front-axle-parts/hub-cone-washer-8mm
martin
CLICK HERE
martin
Last edit: 24 Nov 2009 07:16 by mlines.
23 Nov 2009 17:41 #1509
by mad4x4
Replied by mad4x4 on topic Re:sj free wheeling hubs onto a jimny
Martin, I would think that an 8.8 Grade Steel Counter Sunk Allen screw would be better than a Stainless Steel. The A2 grade may be a bit "soft" since we are putting quite a bit of torque through the hub flanges.
24 Nov 2009 07:16 #1513
Mad4x4,
You are completely correct, I just did a quick search for M8 Countersunk and didn't really look closely at the response.
29 Nov 2009 19:23 - 29 Nov 2009 19:27 #1554
by Garry
Last edit: 29 Nov 2009 19:27 by Garry.
29 Nov 2009 20:14 - 29 Nov 2009 20:15 #1555
Those really do not look like SJ hubs at all. That doesn't mean they won't fit as a number of other hubs fit ok, for example Warn make hubs that fit SJs.
Providing the hubs fit the driveshafts then you will be ok with my spacers and bolts without the cone washers. And you can always sell the cone washers on to the next person who forgets to get them with their SJ hubs!
These are the standard SJ hubs
Here is the countersink and the bolts/cones fitted in the hub.
Last edit: 29 Nov 2009 20:15 by mlines.
Time to create page: 0.199 seconds
