BigJimnyMeet 2024
CB Radio
29 Oct 2021 11:17 #239720
Often comes up as a "modification" for off-roaded JImnys.
I had this offer land in my email this week (I AM NOT ASSOCIATED WITH THIS COMPANY)
Looks a good deal
moonrakeronline.com/intek-m-899-vox-mult...ver?___store=default
Looks a good deal
- Thank you received: 178
- Thank you received: 50
06 Nov 2021 16:08 #239902
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
That does seem good price. I have a full DIN sized CB in my Jimny, slotted in above an aftermarket stereo for tidiness. But I do like the Albrecht one, it's not far off the size of a cigarette packet, can be tucked away easily.
moonrakeronline.com/albrecht-ae-6110-min...dio?___store=default
- Thank you received: 71
- Thank you received: 320
06 Nov 2021 20:21 #239909
by Gadget
Currently in the process of hooking up a CB to my Jimny. Can't get the SWR down below 3 at the moment. Seem to have a decent ground (tested with separate ground strap), cabling all ok and tried two different antenna. Think it might be a dodgy mount, so waiting on a new one to arrive.
07 Nov 2021 17:12 #239930
Did you trim the aerials at all?
18 Nov 2021 12:30 #240175
by Gadget
Thanks for the reply Martin, yes I'd tried everything to no avail. Have now fixed it and it seems to have been the location of the mount.
I had bought one of these backets from Jimnystyle, that sits on the rear door hinge.
I tried it with two different mounts attached, (Thunderpole Powerstick, Thunderpole Chrome) and using two different antenna (Thunderpole Mini Orbiter, Thunderpole 3ft powerstick) but no matter what height adjustment I made the SWR sat in the 'danger' zone on the meter. Both mounts had a good ground (checked continuity many times) and no shorts in the various cables.
I ran out of time to fix the problem before my recent trip to the Yorkshire dales, so had to rely on the tiny rubber duck aerial on my Midland 42DS, which gave me a range of about 100m!
Bought a magnetic mount when I got home, slapped it on the roof today and POW! perfect SWR on all channels straight away. Can only assume that having the antenna sat halfway down the back door meant that a lot of the signal got reflected back. Seems like the Jimnystyle bracket (and APIO bracket that they copied) are only good for looks, not function. Wish I'd known that before I spent a small fortune trying to fix it!
The following user(s) said Thank You: mlines
- Thank you received: 374
18 Nov 2021 13:12 #240178
If the active part of the antenna is not in the clear above the back of the Jimny then the back door will detune the antenna and give you a poor SWR.
Another problem might be the ground plane, the antennas you have used might want to sit on a good ground plane (centre of the roof) or you might have a poor earth if it is through paint, both of these could detune the antenna and give you a poor SWR.
Antennas are balanced and have two elements, like a dipole, but if you don't have the other element (all whip antennas are like this) then using a good ground plane acts like a mirror and gives you the other element.
18 Nov 2021 14:00 #240180
by Gadget
Thanks DrRobin, I know little about antennas. The earth on the bracket was good, I ground it back to bare metal and had continuity between that and a known-good ground point elsewhere.
I tried the second antenna as the first was listed as being 'baseloaded' and like you mention, I was worried that the location would prevent it working properly, but had the same issue with a 'topload' as well (although having subsequently read further, it doesn't sound like that means that all the signal comes out the pointy bit as I'd assumed!
I think it was the lack of a good ground plane that was the big issue. Plonked a 5" mag mount with the Mini Orbitor on the roof and the SWR needle barely moved, whereas before it was flinging itself to the right!
I should probably have gone mag mount to start with, as I'll only want to use it once in a blue moon and having the MIdland 42 with car kit means that the whole setup is easily removable.
18 Nov 2021 14:16 #240181
Base or top loaded refers to where the matching coil is located. The antenna has to be resonant length on the frequency you want to use and CB is near enough 10m, so a 1/4 wave antenna is 2.5m.
The loading coil (base ot top) makes up the difference in length between the antenna and 1/4 wave length, but the coil doesn't radiate, it is the rod or element that radiates.
If the radiating element is very close to a metal surface, the radio waves are reflected back in to the antenna and this gives you a high SWR.
It's a pity as it looks like a really nice mount, the only solution would be to fit a short pole on to the antenna to get the radiating part above the back of the vehicle. Or use an antenna with a long part at the base that doesn't radiate.
Robin
Robin
