BigJimnyMeet 2024
Bolt on turbo
- Motleycrew
- Elite Member
- Thank you received: 23
27 Sep 2021 12:17 #238976
by Motleycrew
Replied by Motleycrew on topic Bolt on turbo
I just loosly put that silicone hose, that rotates 360 of the compressor outlet, so can angle it around it.
- Motleycrew
- Elite Member
27 Sep 2021 20:01 #238987
by Motleycrew
The inlet will be tight! I never thought of that, was really tunnel visioned on the outlet and intercooler routing. I have marked in red where the outlet will be.
- Motleycrew
- Elite Member
27 Sep 2021 20:03 #238988
by Motleycrew
I sorted the oil return at the weekend
- Motleycrew
- Elite Member
27 Sep 2021 20:11 #238989
by Motleycrew
This is what I have already
-link monsoon ecu
-haltech can wideband oxygen sensor
-link knock sensor
-link boost controller
-mazda RX8 injectors
-yaris coils
-Bosch air and coolant sensors
-link monsoon ecu
-link knock sensor
-yaris coils
01 Oct 2021 07:44 #239035
by Keithy
Replied by Keithy on topic Bolt on turbo
- Thank you received: 71
01 Oct 2021 13:07 - 01 Oct 2021 13:07 #239047
by lightning
Replied by lightning on topic Bolt on turbo
Turbocharging a lightweight effectively RWD vehicle like the Jimny should make for interesting driving!
Drive down a damp, leaf spattered lane, plant your toe, and watch the Jimny head for the nearest hedge/field/ditch like a demented clockwork toy
Having permanent 4wd would be a major advantage but it wouldn't be an easy modification to make.
Last edit: 01 Oct 2021 13:07 by lightning.
- Motleycrew
- Elite Member
01 Oct 2021 15:06 #239050
by Motleycrew
Whats up with that hole?
- Thank you received: 552
01 Oct 2021 15:09 #239051
by Scimike
Replied by Scimike on topic Bolt on turbo
It will be fine.
You control the rate at which you "find a ditch" with your right foot, it's simply adjustment of your driving style for the power available.
Plenty of vehicles about before the advent of traction control that had the ability to spin, it's just these days the gizmos to sort it all out for you so people get use driving against the carpet.
Carry on the good work, keep the pictures coming.
- Motleycrew
- Elite Member
01 Oct 2021 15:18 #239052
by Motleycrew
Cheers, its a silly project, will keep all updated though! I have seen a UK based company that sells a limited slip diff for around £700 if its to sketchy.
I decided that half a bar of boost will be safe as HKS sells a turbo kit for the swift m16a. Mine has a liana m16a, which has a more boost friendly compression ratio than that engine so wont be so knock limited whilst tuning.
- Motleycrew
- Elite Member
01 Oct 2021 15:20 #239053
by Motleycrew
01 Oct 2021 20:21 - 01 Oct 2021 20:24 #239057
by lightning
That kit looks good as it appears to include everything that you need, including the ECU.
Has anyone ever managed to modify a Jimny to make it permanent 4wd for road use?
Last edit: 01 Oct 2021 20:24 by lightning.
- Motleycrew
- Elite Member
01 Oct 2021 20:51 #239059
by Motleycrew
The subaru justy had a AWD model and used the suzuki g13b engine in some markets. People use them as a budget rally car
Time to create page: 0.200 seconds
