Its Re:Re:Re:Turning the traction control off (Gen 4)
- Thank you received: 1988
12 Aug 2020 14:21 #226565
Replied by Lambert on topic Re:Turning the traction control off (Gen 4)
I'm so glad my gen3 came with the much more advanced intelligent traction control system. It's becoming obvious that the new one is a definite step back in time.
The following user(s) said Thank You: Busta
13 Aug 2020 21:56 - 13 Aug 2020 22:04 #226630
by crash486
Replied by crash486 on topic Re:Re:Turning the traction control off (Gen 4)
If you are really keen, try one of these.
cartune.me/notes/s7lWlZT203?fbclid=IwAR2...UtGOgU0LXB4ldO4tYWNk
If someone has a service manual, perhaps they can lookup "service mode" related to ESP.
I have read that entering service mode will disable the 30kph enable setting. The whole system is reset via Power off/on.
crash486 JB74W
crash486 JB74W
Last edit: 13 Aug 2020 22:04 by crash486.
- CC Baxter
14 Aug 2020 07:43 #226648
by CC Baxter
Replied by CC Baxter on topic Re:Re:Turning the traction control off (Gen 4)
Anyone else know of this Service Mode? Is it a real thing and if so what can you access/adjust? Chris
14 Aug 2020 08:20 - 14 Aug 2020 08:22 #226654
Replied by mlines on topic Re:Re:Turning the traction control off (Gen 4)
There is a service mode for the ESP.
It is activated either through the Suzuki scan tool or manually by linking pins 1 and 2 on the service connector under the dash and then turning the ESP off by a long press on the ESP button.
Last edit: 14 Aug 2020 08:22 by mlines.
The following user(s) said Thank You: CC Baxter
- GeorgeC
14 Aug 2020 21:04 #226671
by GeorgeC
Replied by GeorgeC on topic Re:Re:Turning the traction control off (Gen 4)
Hi Martin, would there be a similar Mode for the Alternator Control? I would love to re-set the minimum to 12.8V!mlines wrote: There is a service mode for the ESP.
15 Aug 2020 04:40 #226677
George
I wouldn't attribute too much intelligence to the charging system, you may be over-thinking the whole issue. Whilst more complex than the classic charging circuit on older cars, it is still nothing much more than a feedback circuit. A shunt in the battery negative wire provides the ability to monitor the voltage/current being drawn/charged from the battery, ECM "knows" what major circuits are running in the car (lights, aircon etc) and using this information can command the alternator to turn off or on (plus various states of "on") through control of the exciter coils in the alternator. It states that the primary function of this circuit is to generate electricity suitable for the engine speed and electrical load and also to prevent a drop in idling speed if electrical load rapidly increases i.e. limits the Alternator if it detects the electrical load is impacting engine performance.
From the manual, the generator features are as follows:
•Solid state regulator is mounted inside the generator.
•All regulator components are enclosed into a solid mold.
•The IC regulator along with the brush holder assembly is attached to the rear end frame.
•The IC regulator uses integrated circuits and controls the voltage produced by the generator, and the voltage setting cannot be adjusted.
ECM optimally controls the generator output voltage by changing the excitation current and regulated voltage based on the following information.
•Engine condition (ECT, vehicle speed, engine speed, TP, etc.)
•Battery voltage (ECM power supply voltage)
•Electric load condition (blower motor, rear end door window defogger, headlights, radiator cooling fan, A/C compressor, etc.)
•Field coil control duty which indicates the operation rate of the field coil.
•The signal to the “LIN” terminal of the generator adjusts the regulating voltage of the IC regulator, which in turn controls the duty ratio of the field coil and thus the output voltage (“B” terminal output) of the generator.
Regulated voltage 10.6 – 16.3 V at 25 °C (77 °F)
The following user(s) said Thank You: GeorgeC
