How many miles to a tank? Gen 4
- Bill Portland
- Thank you received: 77
28 Feb 2020 21:15 #219204
by Bill Portland
They're designed to stay on for a minimum of 8 seconds to avoid looking like they've just been flashed. Didnt prevent a minibus pulling out in front of me though!
Replied by Bill Portland on topic How many miles to a tank? Gen 4
I'm still wondering about the auto lights, as mine go off even driving under a motorway bridge for a nanosecond, then stay on for a good 10 seconds afterwards. Mind you I don't mind if the driver in front thinks I'm a c*ck - they haven't got a Jimny
- Thank you received: 534
28 Feb 2020 21:18 #219205
by facade
I think the red light is like the one on the early ecoboost- engine failure in 3,2,1 too late! I'd much rather have a nice needle to glance at, or even a degrees C to keep watching.
Clearly I'm in a minority though, or the marketeers at Suzuki would fit one instead of, for example,a shaky steering wheel when I change lanes and a red "CRASH IMMINENT DANGER DANGER!!!" sign every time I slalom through parked cars.
Replied by facade on topic How many miles to a tank? Gen 4
There is a temp sign on dash, blue when cold,goes out when warm, RED over heat. so no need for gauge. Auto wipers bad, dust /mud/sand on screen can fool sensor. Just chews up wiper blades.
- Beaverhausen
- Junior Member
- Thank you received: 1
28 Feb 2020 21:23 #219206
by Beaverhausen
Replied by Beaverhausen on topic How many miles to a tank? Gen 4
Thank you for reminding me!. I'll take the odb reader from Jimny 1, and prop my phone with Car Scanner in the dashboard tray, now I do not need the phone for Waze any more!!
Lots of dials to look at there
28 Feb 2020 21:42 #219207
by Grima
Replied by Grima on topic How many miles to a tank? Gen 4
All car's including trucks fitted with "autonomous braking" do the DEATH, DEATH waring when going around bends with parked cars,some worse than other's not just the Jimny. "Lane departure", use the indictor when changing lanes helps.
- Thank you received: 133
29 Feb 2020 01:24 #219212
by 300bhpton
Replied by 300bhpton on topic How many miles to a tank? Gen 4
Since the mid 1990's many cars, despite looking like they have a temp gauge don't. They essentially show the same as the warning light; cold, normal, hot. They just fool you into looking like a gauge. But only actually have 3 positions.
29 Feb 2020 15:11 #219222
by Grima
01 Mar 2020 19:04 #219256
by treps
Replied by treps on topic How many miles to a tank? Gen 4
I get around 500 kms a tank. And that is with standard 95 octane.
Is it worth running the Gen 4 on 98 octane? Much difference on mpg or performance?
- vecernik87
03 Mar 2020 06:26 #219309
by vecernik87
Replied by vecernik87 on topic How many miles to a tank? Gen 4
@treps: Higher octane number does not mean better efficiency or performance. It just means it will not "kick" (i.e. ignite prematurely due to pressure and heat, before spark plug sparks). That happens typically in engines with high compression ratio. Unlikely to happen in Jimny...
(also, good to differentiate between different octane numbers: RON/MON/AKI...)
The following user(s) said Thank You: treps
- Thank you received: 1661
03 Mar 2020 06:46 #219310
ADOS Attention Defect Ooooh Shiny!
Replied by Lambert on topic How many miles to a tank? Gen 4
On the odd occasion of putting higher spec fuel in Dreadnaught there have been limited improvements in performance but not in the kind of way that the additional cost of the fuel could be justified or that the increase could be could be repeatedly quantified. It's not like the difference between running a jdm engine mapped for 100 octane on 95 vs 99.
03 Mar 2020 16:51 #219331
by treps
Thanks. So what is the recommended fuel for the Gen4?
From the definition, am I right is concluding that putting 98 is a waste?
- petejones69
- Premium Member
- Thank you received: 6
05 Mar 2020 20:46 #219438
by petejones69
1999 Jimny with 3" lift, Redacted transfer box, under-body protection, Cooper STTs and folding cup holders...
Replied by petejones69 on topic How many miles to a tank? Gen 4
I get around 200 miles from a tank full, standard petrol.
05 Mar 2020 20:54 - 05 Mar 2020 20:56 #219440
by 300bhpton
290 miles on the trip tonight. Managed to squeeze in 35.02 litres.
Trouble is, you are driving completely blind. I accidentally reset the mpg trip at the last fill up and it hasn’t quite risen to the same number yet (still climbing). I also forgot to fill up last night and the fuel light came on this morning on the way to work. Sadly I don’t pass a Petrol station. Had to take a detour on the way home to find one. But as it turns out I could easily have made it home and then onto the local petrol station. If only the car was able to tell me how much fuel was actually left onboard
Last edit: 05 Mar 2020 20:56 by 300bhpton.
Time to create page: 0.215 seconds
