BigJimnyMeet 2024
Stuck in 4wd
- Mattch5150
- Visitor
29 Dec 2018 20:01 #199672
by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
I think there is a few threads on here 're faulty actuator wiring, the black and white ones, I think this one has had a hard life at some point!
- Johnniehec
- Thank you received: 56
29 Dec 2018 23:49 #199691
by Johnniehec
Replied by Johnniehec on topic Stuck in 4wd
Sorry but if fuel is leaking from the filler pipe wher it goes into the tank you’re going to need a new or second hand tank. Mine had a stupid bit of foam rubber round that bit of the pipe which holds the salty water off the road. Mine got a bit of a prod off road and broke completely but it was well rotten.
- Mattch5150
- Visitor
30 Dec 2018 07:55 #199695
by Mattch5150
Have looked everywhere and cannot see new or used tanks anywhere for them. Will have to check It all out first.
- Mattch5150
- Visitor
30 Dec 2018 09:39 #199698
by Mattch5150
I presume fitting a new tank would be a nightmare and Very expensive?. It hopefully is repairable by some method. I
30 Dec 2018 09:44 #199700
by Busta
Replied by Busta on topic Stuck in 4wd
Not at all. Find one in a breakers yard or ask a mechanic to find one for you and fit it. Should only be a couple of hours labour.
- Max Headroom
- Banned
- Thank you received: 217
30 Dec 2018 10:40 #199703
by Max Headroom
Replied by Max Headroom on topic Stuck in 4wd
I know you dont need the extra work with this car, but if it was my car and me doing the job I'd get myself a largish tub of
THIS UNDERSEAL
or similar, get the old tank out, paint the area above the tank with it, and the top/inaccessible areas of the tank with the underseal, fit the replacement tank, and finally paint the remaining bits of the tank. Change any rubber seals etc as well.
This is messy stuff but well worth the hassle (and mess).
Last summer I found the sender unit on my old MG was failing. To change that meant getting the tank off (stupid design) but I found the seam around the top of the tank had started to exfoliate and leak so replaced the tank as well. I used the same underseal as I just described
- Mattch5150
- Visitor
30 Dec 2018 10:44 #199705
by Mattch5150
Are the ignis 4 grip any good?
- Thank you received: 653
30 Dec 2018 12:41 #199709
Replied by jackonlyjack on topic Stuck in 4wd
James will have a second hand tank here's is user profile send him a PM
www.bigjimny.com/index.php/forum/profile/1482-j999pre
- Mattch5150
- Visitor
31 Dec 2018 14:31 #199779
by Mattch5150
The jimny is being part exed. Its my gfs car any way not mine. She has bought a Toyota rav 4 2.2 diesel 2009 model from a dealer I've used for past 20years. Got full warranty etc and will suit her needs better. Thanks for everyone's help on here, it's helped me do many a job on the jimny
Cheers
Matt
Cheers
Matt
- Mattch5150
- Visitor
03 Jan 2019 17:48 #199964
by Mattch5150
Again thanks for all your help. I've requested my account to be closed. Jimny is worst car I've ever driven, I think it should be off road only, but I see where the affinity comes from. Biggest issue is terrible rust, like Japanese cars from the 70s. Good luck to you all, and again thanks
Time to create page: 0.132 seconds
