Turbo M16A Jimny
02 Feb 2022 17:31 #241683
Replied by Riccy on topic Turbo M16A Jimny
Sorry, I cant remember that bit. Can you post a picture to help me?
If its any help heres a couple of pics of the manifold off the car...
- Probablynotfrank
04 Feb 2022 23:42 #241704
by Probablynotfrank
Replied by Probablynotfrank on topic Turbo M16A Jimny
Perhaps the 2 coolant lines that are there to prevent icing up inside the throttle body?
- Motleycrew
Topic Author
- Elite Member
- Thank you received: 23
08 Feb 2022 20:37 #241758
by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Got the old knock sensor off and got the stud on for the new Bosch sensor to slide on. was probably the worst job on the car so far! No room to work and kept dropping tools and bits onto the engine mounts.
- Motleycrew
Topic Author
- Elite Member
08 Feb 2022 21:35 #241760
by Motleycrew
good point
- Motleycrew
Topic Author
- Elite Member
09 Feb 2022 20:04 #241770
by Motleycrew
Yellow RX8 injectors installed, and brown Liana injectors removed. Knock sensor fitted. Started tweaking the inter cooling pipes and cutting some to size. Ideally I should of got a 120 degree angle bend for the throttle body to meet the intercooler but it will work. Turbo outlet to intercooler has matched up well.
- Motleycrew
Topic Author
- Elite Member
10 Feb 2022 18:18 #241776
by Motleycrew
Plumbed in turbo oil feed and return. Connected all intercooling. Have put a port in for a HKS blow off valve. The intercooler is on a slant which I am not happy with but it’s something I can rectify later on.
Time to create page: 0.363 seconds
