Turbo M16A Jimny
23 Feb 2023 21:41 #247726
Replied by Soeley on topic Turbo M16A Jimny
Very neat!
24 Feb 2023 05:57 - 24 Feb 2023 05:58 #247729
My 05 Jimny had a plastic steering wheel but my current steering wheel is from a newer 2012 (?) Jimny with nice leather and a bit thicker wheel.
No airbag warning lights came up as the airbag was moved over and was hooked up with the battery disconnected. haven't tested the airbag though, hope I'll never have to
Replied by yakuza on topic Turbo M16A Jimny
Somebody put a Swift wheel or some other Suzuki in a Jimny with all the working wires for the steering wheel buttons. Not sure if it was here I saw it but it is possible.need to replace the steering wheel. The rubber has come loose from the metal. The jimny steering is vague enough let alone when the actual wheel moves! was looking a few options:
-replace original for same generation (looks most sensible)
-put one on from a swift sport (not sure if it will fit)
-put quick release and delete airbag (never a good idea to remove life saving devices)
any ideas?
Last edit: 24 Feb 2023 05:58 by yakuza.
The following user(s) said Thank You: Motleycrew
- Motleycrew
Topic Author
- Elite Member
- Thank you received: 23
24 Feb 2023 06:13 #247730
by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Apexi air filter put on. The other Ram air one started melting on the rubber lip! Thought I would get the one that has proven performance increases whilst providing decent filtration. Car goes in dyno today. Will up from .4 bar to .55 bar (6psi to 8psi) that increase with the free flowing exhaust should really make a substantial performance increase. Nervous that it goes well. The engine hasn’t missed beat so far.
- Motleycrew
Topic Author
- Elite Member
24 Feb 2023 06:14 #247731
by Motleycrew
Does anyone know the ID of the power steering reservoir hoses? Need to relocate it
- Motleycrew
Topic Author
- Elite Member
28 Feb 2023 17:22 #247794
by Motleycrew
- Motleycrew
Topic Author
- Elite Member
28 Feb 2023 17:27 #247795
by Motleycrew
Half a bar of boost making 156BHP big increase in Torque low down. Standard 1.3 Jimny has 81lbf-ft and the liana m16a turbo engine is now making 148 lbs-ft!
Time to create page: 0.172 seconds
