Dave’s long-term Lil’Bugga Buggy Build
  • Lil-Bugga
20 May 2021 14:50 - 20 May 2021 16:25 #235231 by Lil-Bugga
Ah, sigh of relief, The Boogie buggy build is coming to an end, and I plan on driving it as much as I can over the summer months... B)
I’ve really enjoyed building it, and it’s kept me safe and sane over the (winter) COVID lockdown... I’m super happy with it, it’s ideal for greenlaning, and has a windscreen and vinyl soft-top roof to keep me dry on rainy days... And it still resembles a Jimny, which was needed for MOT, insurance and road legality purposes...
BUT... I still long for a tubular roll-caged / framed single seater buggy, so in March I messaged our mate James Priestley (who breaks the odd Jimny) and gave him a list of what I was after..
In early April James messaged me back to say he had most of it amassed! Ummm, so in mid-April when lockdown restrictions allowed I went up and loaded the NGeeVee with bits! -
Two front axle casings / hubs
Two front diffs
One pair of (both) short front shafts (?!)
Four front radius arms
Two sets of steering bars
Two power steering boxes
One power steering pump
One power steering reservoir tank
Four alloy wheels
A pair of JimnyBits HD panhard rods
Hmmm...
Yes, starting in the winter, I’m going to attempt to start building a four wheel drive, four wheel steer, four wheel disk braked (fiddle brakes then.) off-road-only buggy... just for the fun and challenge of building it, and possibly the odd AWDC competition, if and when it gets finished...
Progress will be slow, no rush, take my time and potter when I have spare time, so probably over the next few years / winters...
I’ve also picked up a reverse (starter) motor kit, as it will undoubtedly be bike engine based...
so it will be drilled thus -
to fit on the intermediary prop between the bike engine and the rocklobster transfer box I also have sat around...
And then these arrived...
Four standard front springs, four looong shocks from Russ at JimnyBits, spring clamps for dislocating springs, and panhard rod bushes.. to be fitted once the panhard rods have been shortened and rewelded (?)... Ah, yes, I forgot that bit ;) hence the short side shafts... the axle tubes are going to have 12” cut out of them to make a smaller, narrower buggy, and using two front axles will make the length shorter too...
 So the parts are sat at the back of my garage waiting for a start in probably September... but my crazy min is working overtime!!! ;)
Last edit: 20 May 2021 16:25 by Lil-Bugga.
20 May 2021 15:41 #235232 by Lambert
This is going to be fun!
The following user(s) said Thank You: Lil-Bugga
20 May 2021 17:10 #235234 by Soeley
Bring it on
26 May 2021 09:38 - 26 May 2021 13:54 #235384 by X8GGY
Small  update...
When I went up to James Priestley's to pick up a replacement gearbox for the Boogie, I also came back with -
A burgundy (not for long!) bonnet (s it will be cut down to scale for the lil'bugga), and a pedal box assembly...
At the start of our latest greenlaning trip Riccy gave me an additional short front shaft in some kind of deal with James, and lent me a long shaft to have a look at and a measure -
So at the top, a long shaft to measure to work out the difference between it and a short one, as that's how much will need removing from the two front axle tubes... The two short sided standard 22 spline shafts for the front front axle ;) And at the bottom two TrailGear 26 spline HD short shafts  and HD CVs for the rear front axle... :lol:
During a WhatsApp conversation with Riccy he pointed out that the rear front axle will turn the wrong way... (and try and tear the lil'bugga apart!) I'd thought about if for a while in the shop, weirdly twirling my fingers trying to work out the rotation of the  props, etc. and thought it would work! :lol: But no worries -
Referencing this old photo from the Boogie build thread, you can see that a Jimny's front diff is high-pinnion, the pinnion is at the top where the prop enters the back of the diff, so I'm hoping I should just be able to flip the diff over, make it low pinnion (more oil for the pinnion!) and that will make the rotation right...
Andy "Baloo" has pointed out on his Lightwight Buggy Build Thread that if you narrow a front axle -
There's not much width left / no turning circle... but look at those MAHOOSIVE tyres! :woohoo: , I'm only planning on going for 215/80-15 Special Track tyres, as it's a small buggy, so everything is to a matching small scale, hence "lil'Bugga" !
We'll see, when things start in the autumn / winter...
Last edit: 26 May 2021 13:54 by X8GGY.
26 May 2021 10:10 #235387 by Roger Fairclough
Hi Dave.
I have followed your Buggy build with considerable interest and awe. I don't think I would have lasted more than half way before giving up.
The idea of building Little Buggy with 4 wheel steer will give you an amazing turning circle but as has been pointed out you will have trouble with diff. rotation, so I have a few points to consider.
If you turn the diff round to give a low pinion set-up you will/may have the problem of the crown wheel hitting the wall of the diff. housing. This is the part that has the filler plug. You can overcome this by, knocking out the indent, or cutting the whole back plate off and turning 180 deg. and relocating the filler plug.
Or,
Keep the rear diff casing as is and grafting on the hubs from the front axle.
First idea is probably the easiest with the last the hardest. It's all about getting the alignment right.
Roger
26 May 2021 11:20 #235391 by X8GGY
THANKS very much Roger! ;) I'll look out for that when I get to that part...
Cheers! Foresight is a wonderful thing! B)
Time to create page: 0.214 seconds
