Dave’s long-term Lil’Bugga Buggy Build
- Dirtbird
17 Aug 2021 19:23 #237677
by Dirtbird
Replied by Dirtbird on topic Dave’s long-term Lil’Bugga Buggy Build
This is them Blitzworld BuggiesLOL! :lol: Yes, exact same seat?! Weird!
Yes, remember that from back in the days of Difflock. fella spent a fortune on it... racking my brain for his name...?
- X8GGY
19 Aug 2021 04:46 #237707
Replied by X8GGY on topic Dave’s long-term Lil’Bugga Buggy Build
- Baloo
20 Aug 2021 17:02 - 20 Aug 2021 17:02 #237743
by Baloo
Replied by Baloo on topic Dave’s long-term Lil’Bugga Buggy Build
hi Dave
that yellow buggy is super cool i could easily be persuaded not to use a jimny chassis and build one like that lol, only reason for the jimny chassis was to keep it road legal but i could live with trailering it around
are you definitely going to narrow your axles ? are you planning on using jimny coil springs ?
Last edit: 20 Aug 2021 17:02 by Baloo.
- Dirtbird
21 Aug 2021 15:54 #237760
by Dirtbird
- Dirtbird
21 Aug 2021 15:56 #237761
by Dirtbird
This is going to work out well as I've got a second set of Jimny parts, going to try and get the transnational back together first.
- X8GGY
22 Aug 2021 10:25 - 22 Aug 2021 10:28 #237777
Yes, Jimny coil springs that will dislocate, due to super long shocks...
4x new standard Jimny front springs, 4x JimnyBits “Black Raptor” brand +5″ rear Grand Vitara gas shock absorbers, and four spring clamps.I don’t want too much lift with the buggy being short and narrow, but it needs to have plenty of articulation, so the springs will dislocate at the top, and be held in place by the spring clamps which are attached to the spring cups on the axles.The shocks are 29″ at full droop and 15″ compressed, so that gives me plenty to play with when the suspension is setup during the build…
Lots of unsprung weight (axles wheels and tyres) and a small light buggy on the top
I looked at air shocks, rod end links, etc, etc, but this is just a simple cheap build again using easily sourced repair parts, to keep me sane in the garage...
Yes, determined to use to narrowed front axles, I want a small one seater buggy, and it has to be about the size mentioned above to be able to get both buggys in my garage...hi Dave
Last edit: 22 Aug 2021 10:28 by X8GGY.
