BigJimnyMeet 2024
jimny pickup finaly getting finished
- Thank you received: 47
05 Apr 2020 18:00 #220733
by Jimny Dr
Replied by Jimny Dr on topic jimny pickup finaly getting finished
- Visitor
05 Apr 2020 18:40 #220734
Replied by Daniel30 on topic jimny pickup finaly getting finished
Very nice....
05 Apr 2020 19:40 #220735
by HUN
I've just noticed you guys left the vacuum pipes in place. Are you planning to use them? If so it might be worth replacing them with new copper ones?
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic jimny pickup finaly getting finished
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
05 Apr 2020 20:04 #220740
by Jimny Dr
Hi hun
Yes we tasted all the vacuum system and it worked fine so there ok to go again, but we replace the pipes on the axle with silicone hose regardless
When we do the rebuild
Thanks
The doc
Thanks
The doc
- Thank you received: 305
06 Apr 2020 12:51 #220752
by sniper
Replied by sniper on topic jimny pickup finaly getting finished
Great stuff Doc....
Are you doing any mechanical work while the cab is off..?
sniper
sniper
06 Apr 2020 17:29 #220756
by Jimny Dr
Hi sniper
Yes we will be rebuilding the gearbox with bearings and seals, fitting new clutch unit at same time.
Then we will work from front to back of the chassis doing brake pipes radius arm caster correct bushes then the rest in polybush new 2” black raptor lift kit aswell.
This is going to be a nice little work horse for some one when it’s done, you know me sniper it has to be Wright
Our moto is do it Wright do it once
Pictures of today’s progress to follow
The doc
The doc
06 Apr 2020 17:33 #220757
by Jimny Dr
The following user(s) said Thank You: Max Headroom
- Reason2doubt
- Thank you received: 100
07 Apr 2020 02:41 #220761
by Reason2doubt
Replied by Reason2doubt on topic jimny pickup finaly getting finished
Looks awesome; looking forward to more updates!
07 Apr 2020 19:18 #220787
by Jimny Dr
07 Apr 2020 19:56 #220790
by sniper
You look like you had to chop a fair bit out Doc, I'm sure that most cars of the period must be the same. I suppose 15yrs ain't too bad, but they are going to become rare unless the newer ones don't rust so bad....
sniper
sniper
07 Apr 2020 21:07 #220794
by Jimny Dr
Good evening sniper
Yes I’ve done a few of these now and they all suffer tin worm in the same areas for some reason weather it’s poor cavity protection from new or
Just poor quality steel,
Bet yes they worth saving so I try to cut out as far as needed then replace with new to give then a better chance of survival
Plenty of wax inside cavities when done is the best we can offer the little gems
The doc
The doc
10 Apr 2020 17:34 #220900
by Jimny Dr
