Ulysses
19 Sep 2021 16:57 #238794 by jackonlyjack
19 Sep 2021 17:47 #238800 by LesNewell
Replied by LesNewell on topic Ulysses
Dirtbird, yes those are the ones. If you go for the Tecarc branded version in the UK they are £770 from welding supplies direct . Still a substantial chunk of cash if you don't use it on a regular basis.
Riccy, that's a really nice solid looking repair. It should outlast the rest of the vehicle.
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
25 Sep 2021 15:03 #238938 by Riccy
Replied by Riccy on topic Ulysses
back one finished off today. Made a C section bit of steel to fill in the rear skin I had chopped off and drilled some large holes in the skin to allow cavity wax to go in and dampness to evaporate out. 2 coats of buzzweld RCP and leave to dry. Turned it round and onto ramps to have a look at doing the front two (or at least make a start on them) tomorrow.
25 Sep 2021 17:21 #238939 by sniper
Replied by sniper on topic Ulysses
Nice work mate, looks like you saved it....
sniper
25 Sep 2021 20:08 #238944 by Lambert
Replied by Lambert on topic Ulysses
We always have faith in your ability to keep ulysses going.
  • Riccy
  • Banned
  • Banned
26 Sep 2021 15:27 #238959 by Riccy
Decided to tackle the driver side one first. Cut a hole in the floor and slowly made it bigger until I found metal solid enough to weld to. The body mount pin was detatched from the outer skin and resting on the inner, same as the rear.
Cut some profile from a bit of 50x100 box but couldnt get it to fit well and its shape was wrong for the job really:
Time for lunch and a think. Decided to start again with some 3mm flat bar I had. Much messing about to get it the right shape to fit fairly snug and then weld-a-thon to stick it in place. Need to patch the floor back in again but I'm happy that its solid enough now. Next weekend to finish off this and the other front one, then an outing on 10th to look forwards to around Penrith/Alston area.
Time to create page: 0.197 seconds
