Soeley's 2019 Black SZ5
- Thank you received: 613
07 May 2020 15:39 #221992
Replied by Soeley on topic Soeley's 2019 Black SZ5
Here is the final instalment of my blackout blinds.
So for the front side blinds I couldn't use magnets, not enough bare metal and no overlap on the blinds themselves. So I stitched some black plastic packers I had on to the edges, they just push between the glass and seal nicely.
The rear blind I stitched some 2" webbing around and glued magnets to it. That one like the rear sides, lives rolled up in place ready for use, by the way of some straps wedged between the glass and frame.
The windscreen blind I bought some double sided suction cups, these work better than the ones supplied with the blinds.
All the blinds are reversible if you want to use them as sun shades or black side out for more stealth.
04 Jun 2020 18:10 #223262
Last week I fitted the extended brake pipes front and rear. In hindsight I'm glad I did those first, as yesterday it made it easier and didn't even have to remove the front calipers to get enough axle droop to remove the springs.
Jimny up on axle stands and a scissor jack at each end of the axle made for controlled lowering.
Radius arm bolts were loosened before allowing axles to fully droop.
The rear bump stops were the worst part. If you have sausage fingers forget it
I haven't fitted the supplied castor correction bushes yet, going to get a feel for it first and see if fitting them does improve anything. Steering wheel is slightly off to the right though now due to the lift, I believe a little adjustment to the draglink is needed.
Been for a quick test drive and no strange noises or clunks which is good. It does feel a little firmer on the road but not jarring, will dry some speed humps later and see it it feels different over them.
I think that about covers it.
So all I have to do is park here and it happens by magic, right?
Old v New, shock removal was straight forward.
Front hub vacuum pipes pulled and capped off. Speed sensor wire bracket unbolted on the right.
And a plastic clip pulled out for the sensor wire. This gave plenty enough slack to fully lower the axle to get the springs out. I did also undo and lower one end of the cross brace to allow the prop shaft to come all the way down.
Spring compressors were used as well just to squeeze the springs a bit. Only used a ratchet spanner on them.
Old v New.
Both sides with new springs and shocks fitted and cross member bolted back in place.
I didn't like the look of the strain on the vacuum pipes, not even pushed all the way on.
Vacuum pipe bracket above the chassis rail. Leans backwards slightly.
A bit of a bend to make it lean forwards.
Pipes now pushed fully home and don't look as stressed.
Front finished.
For the LED headlight version a longer rear axle to level sensor is supplied.
Rear shock absorber lower bolts are straight forward to remove. Again Jimny on axle stands and scissor Jack's under each trailing arm to support the axle.
Top RH shock mount, the bolt is trapped by this cable.
Undo cable bracket to gain more clearance.
Rear speed sensor cable clip pulled free.
Sensor wire bracket unbolted.
And another one on top of the diff. Again these gave enough slack to fully lower the rear axle without straining the wires.
Old v New.
With the OME kit you get a Panhard lower relocation bracket. I was concerned with the gap, but the bracket closed up when the bolt was torqued up.
Thought I'd measured it correctly
Close though. Suspension may settle a bit though.
And by magic :woohoo:
Old v New.
Front finished.
Old v New.
The following user(s) said Thank You: PabloAzH
05 Jun 2020 21:25 #223293
- Thank you received: 96
07 Jun 2020 16:18 #223350
by DAGZOOK
Replied by DAGZOOK on topic Soeley's 2019 Black SZ5
Well done Soeley, Lovely job me old mate! I thought I saw in an early picture that the OME kit was supplied with the polyurethane spring seats/spacers.
The front set up looks almost identical in terms of shock length (Old vs New) but there's a clear difference in the rear. Maybe it was just the angle of the photo.
Keep us updated with a long term review going forwards :silly:
07 Jun 2020 17:26 #223355
Thanks DAGZOOK, Storm/Jeepy sell the kit with the 10mm spring spacers, it might be that one you have seen.
07 Jun 2020 18:21 #223361
by 300bhpton
Replied by 300bhpton on topic Soeley's 2019 Black SZ5
Looking good
Are tyres on your list next?
How do you find the ride/handling on road vs the standard shocks/springs?
Time to create page: 0.230 seconds
