Just purchased my first Jimny
29 Jan 2019 22:58 #202055
by adrianr
Thanks.
Back left seat is folded down and my large plastic box of tools and stuff is wedged up against the base of the folded up seat. There is just enough room to wedge the battery between the other end of the plastic box and the rear door of the Jimny. My compressor and small holdall of other tools are to the right of that behind the other back seat which is in the normal position, so the battery is wedged in good and tight.
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Just purchased my first Jimny
Max Headroom wrote: Good work Adrian.
...And I like the idea of carrying a spare battery just in case. However, make sure it can't fall over and leak acid everywhere! :ohmy:
Thanks.
- Max Headroom
- Banned
- Thank you received: 217
30 Jan 2019 06:22 #202058
by Max Headroom
Good that is the case.
A long time ago, far away in another life. a friend of mine with a lovely Triumph 2000 was taking a spare battery to the gliding club to use for operating the signal luights on the 'launch control bus'. At some point in the one hour journey the battery tipped over. By the time he got there the carpet was totally ruined and he had a huge clean-up job to do, not to mention neutralising the acid to stop corrosion.
Replied by Max Headroom on topic Just purchased my first Jimny
adrianr wrote: the battery is wedged in good and tight.
30 Jan 2019 08:22 #202066
by adrianr
That sounds very messy. Nasty stuff inside batteries. I am always wary of them, and the weight of them if they are not well secured.
30 Jan 2019 08:53 #202068
by adrianr
Lovely snow...... need to go and play higher up in the hills with Wee Jimmy.
- Thank you received: 2004
30 Jan 2019 09:02 #202070
Replied by Lambert on topic Just purchased my first Jimny
That's an oxymoron. There is nothing lovely about snow!
30 Jan 2019 09:14 #202071
by adrianr
As a farmer, definitely not.
Time to create page: 0.192 seconds
