Just purchased my first Jimny
13 Feb 2019 07:29 #203089
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Just purchased my first Jimny
Will do. No ABS on mine though.
- Thank you received: 2001
13 Feb 2019 07:49 #203090
Replied by Lambert on topic Just purchased my first Jimny
Ah ok. Will be interested to see if it matches the GPS then.
13 Feb 2019 18:27 #203133
Does it really do that? I doubt it knows what the speed of the wheel is by the ABS sensor, unless its tapping into some sort of traction control system maybe?
The standard jimny has a speedo sensor on the rear output of the transfer box, likley the same for you Lambert? I would imagine the device is simply reading the ECU data from that sensor? Is there a correction option in the menu for that? I think Dave (S200KYS) has one of these and thats mainly what he wanted it for...
Replied by Riccy on topic Just purchased my first Jimny
Lambert wrote: Ley us know how you get on with it. Especially the speed, I'm interested in how the ecu calculates it. As in does it cross reference the gearbox output sensor with the abs sensors to account for tyre size and wear to keep the odometer accurate etc etc.
13 Feb 2019 18:56 #203138
Yeah it does have the correction facility but just using the raw data it's reading correct to the gps not the cluster and i know for a fact that even though my bfg's are 205's they are noticeably taller than the duelers it came with. Hence wondering if the abs and propshaft sensors are correlated in some way?
13 Feb 2019 19:02 #203142
Maybe you've found the sweet spot with the tire's it should have came fitted with in the first place :laugh:
15 Feb 2019 07:56 - 15 Feb 2019 08:14 #203248
by kirkynut
Replied by kirkynut on topic Just purchased my first Jimny
You've realised my dream of green with old english white/cream wheels!
I'm a bit behind I know but I don't get on here as often as I'd like these days.
It looks every bit as good as I'd envisaged it would and you've done a grand job!
I think that if I were to buy another Jimny I would get one in this green and paint the wheels the same colour as you have with a Trailmaster 2" Comfort lift kit and a Jimny Bits hidden winch mount behind the front bumper housing a Goodwinch 9500lb winch. It would wear 215/75/15 BFG mud terrains on standard gearing. It would also have a full length roof rack like Dave Jones has, as they sell in Jimny Bits too. That would make me happy to have as a daily.
Last edit: 15 Feb 2019 08:14 by kirkynut.
The following user(s) said Thank You: adrianr
Time to create page: 0.619 seconds
