The Jimny of the Yakuza
  • OlaGB
24 Apr 2018 06:02 #192101 by OlaGB
Replied by OlaGB on topic Re:The Jimny of the Yakuza
Great news! Must be good to get rid of o many annoying issues now then!
Was the gear shift mechanism on the box, or did you reuse youre old? I`m wondering why the shifter feels tighter, usually only due to bushings.
24 Apr 2018 07:41 #192104 by yakuza
Replied by yakuza on topic Re:The Jimny of the Yakuza
Reused the old bracket and shifter so it's all down to the gearbox itself.
Could also be the clutch releasing better.
Even though the clutch now grips lower on the pedal adjusting the wire more correctly.
  • Daniel30
24 Apr 2018 08:42 #192107 by Daniel30
Replied by Daniel30 on topic Re:The Jimny of the Yakuza
Yep sounds just like mine feels like a new car :)
25 Apr 2018 05:55 #192132 by yakuza
Could also be that the clutch construction is a balance between the pedal pressure and the internal spring pressure in the clutch. When they construct the clutch they need gripping power and by using low quality clutch plate material they would need stronger springs, and thus more pedal power to release.
That is when the clutch wire and brackets begin to bend and stretch over time i guess..
With a better quality clutch the systems total balance and thus its function gets to be way better.
-in theory :)
27 Apr 2018 04:42 #192213 by HUN
Replied by HUN on topic Re:The Jimny of the Yakuza
Hi Yakuza.
Do you have a definite list about R72 type (year 2005) gearbox? I mean which parts should be replaced with new/upgraded parts in order to improve reliablity of this type?
I bought and got fitted another used R72 type gearbox last summer so I have the old one ready for rebuild.
My old R72 type gearbox has good gears but sync rings and bearings may need to replaced with new ones hence I'm asking.
Thank you for any advice.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
27 Apr 2018 06:42 - 27 Apr 2018 06:43 #192215 by yakuza
HUN wrote: Hi Yakuza.
No I do not have such info other than the bearing kits on ebay has closed bearings, my 2013 gearbox has closed bearings as i have seen with my endoscope, and my 2005 box had open bearings. this upgrade came 2009/10 i have read somewhere. (in here i think?)
The refurbished gearboxes sold have new gearwheels, bearings and sync rings one seller told me.
I too have been thinking about rebuilding and upgrading my used and crashed gearbox. But it would need most gearwheels and of course everything else in there that is damaged. I would have to check shafts and housing thoroughly so I might just do a core swap when i buy a new or refurbished gearbox sometime in 2026 when this new one breaks down...
Last edit: 27 Apr 2018 06:43 by yakuza.
Time to create page: 0.230 seconds
