Ollie's Lil Blue Jim.
- GraphicX
- Visitor
14 Jun 2016 04:18 #168506
by GraphicX
Replied by GraphicX on topic Ollie's Lil Blue Jim.
previous owner do a dodgy you think ? seems to be tons of it that's for sure.
- OllieNZ
- Visitor
14 Jun 2016 10:22 #168519
by OllieNZ
Replied by OllieNZ on topic Re:RE: Ollie's Lil Blue Jim.
Not really, I bought it knowing it had a head gasket issue but didn't get the head pressure tested when I had it skimmed so more fool me really.GraphicX wrote: previous owner do a dodgy you think ? seems to be tons of it that's for sure.
- OllieNZ
- Visitor
18 Jun 2016 16:16 #168794
by OllieNZ
Replied by OllieNZ on topic Re:Ollie's Lil Blue Jim.
- OllieNZ
- Visitor
18 Jun 2016 16:43 #168795
by OllieNZ
A couple of thoughts on the job.
If you plan on removing the box or you've only got the front in the air, drain the box before removing the output propshaft or you'll be swimming in gear oil (guess how I found that out....)
If you are just doing the clutch you shouldn't have to totally drop the box if you remove the rear mount/linkage assy (you're supposed to do this anyway) and prop it will pull back far enough to give you plenty of room.
If you do decide to pull the box you can do it without removing the exhaust and front prop but you need to remove the 2 studs from the bottom front of the box, the rubber rear mount itself and the exhaust hangar bracket off the rear mount bracket (one bolt). With a bit of fiddling it will drop out.
- OllieNZ
- Visitor
18 Jun 2016 16:48 #168796
by OllieNZ
- GraphicX
- Visitor
23 Jun 2016 06:34 #169032
by GraphicX
how are you finding the feel of the HD clutch, much heavier under the pedal ?
i fitted a new clutch when i swapped the motor, but it was an OEX or something & i'm unhappy with it, awful pedal feel & it tends to slip & stink of burning.
Time to create page: 0.139 seconds
