Ollie's Lil Blue Jim.
  • OllieNZ
  • Visitor
  • Visitor
27 May 2016 19:50 #167605 by OllieNZ
Warning: Undefined variable $end_tag_params in /mnt/Main_Volume_2/www/bigjimny.com/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
Replied by OllieNZ on topic Re:Ollie's Lil Blue Jim.
A little bit more work today,
Changed the water pump and the front crank seal.
New seal on the left
[IMG
Impromptu crank bolt removal tool ;)
[IMG
[IMG
And finished up by prepping the top of the block and cleaning all the swarf our of the bores
[IMG
  • gusthegorilla
  • Visitor
  • Visitor
28 May 2016 11:39 #167624 by gusthegorilla
Replied by gusthegorilla on topic Re:Ollie's Lil Blue Jim.
Nice work Ollie...is that your temporary transport sitting on the porch ? :whistle: :whistle:
  • OllieNZ
  • Visitor
  • Visitor
28 May 2016 11:42 #167625 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:Ollie's Lil Blue Jim.
gusthegorilla wrote: Nice work Ollie...is that your temporary transport sitting on the porch ? :whistle: :whistle:
Thanks Gus,
Sure is ;) but my 5 year old son is not so keen to loan it out.
  • the_goshawker
  • Visitor
  • Visitor
29 May 2016 14:33 #167678 by the_goshawker
Replied by the_goshawker on topic Ollie's Lil Blue Jim.
To scary looking for me, this thread needs a warning at the start :S :S :S :S :S :S :S
  • OllieNZ
  • Visitor
  • Visitor
29 May 2016 15:00 #167683 by OllieNZ
Replied by OllieNZ on topic Re:RE: Ollie's Lil Blue Jim.
the_goshawker wrote: To scary looking for me, this thread needs a warning at the start :S :S :S :S :S :S :S
Lol
I'm a mechanic (aircraft day to day, cars only as required) so tbh most of this stuff is just another day at the office for me.
I hope sharing will help others, the g13bb is a very simple engine to work on and with the manuals readily available many tasks that appear daunting really aren't.
  • OllieNZ
  • Visitor
  • Visitor
11 Jun 2016 12:29 #168345 by OllieNZ
Finally back on the road :)
I was under a bit of pressure to get it done so a little light on pictures sorry.
Refurbished head.
[IMG
I had to swap a few bits from the old head...
No studs
[IMG
No problem
[IMG
Simply wind 2 nuts onto the stud and tighten them against each other then wind the stud out like a bolt, install the stud into its new location and lose the nuts and remove them. Repeat as required and presto job's a good un.
[IMG
I also had to swap my camshaft in, which turned out to be a good thing as it had be incorrectly assembled. All the journal bolts had been fitted dry and massively over torqued.
Also managed to misplace my cam position sensor and housing so thanks to James (J999pre) for sorting me out with another one :)
Found this in the back end of the old head
[IMG
K seal anyone?
  • GraphicX
  • Visitor
  • Visitor
14 Jun 2016 04:18 #168506 by GraphicX
Replied by GraphicX on topic Ollie's Lil Blue Jim.
previous owner do a dodgy you think ? seems to be tons of it that's for sure.
  • OllieNZ
  • Visitor
  • Visitor
14 Jun 2016 10:22 #168519 by OllieNZ
GraphicX wrote: previous owner do a dodgy you think ? seems to be tons of it that's for sure.
Not really, I bought it knowing it had a head gasket issue but didn't get the head pressure tested when I had it skimmed so more fool me really.
  • OllieNZ
  • Visitor
  • Visitor
18 Jun 2016 16:16 #168794 by OllieNZ
New exedy clutch now fitted.
Old vs new
[IMG
  • OllieNZ
  • Visitor
  • Visitor
18 Jun 2016 16:43 #168795 by OllieNZ
A couple of thoughts on the job.
If you plan on removing the box or you've only got the front in the air, drain the box before removing the output propshaft or you'll be swimming in gear oil (guess how I found that out....)
If you are just doing the clutch you shouldn't have to totally drop the box if you remove the rear mount/linkage assy (you're supposed to do this anyway) and prop it will pull back far enough to give you plenty of room.
If you do decide to pull the box you can do it without removing the exhaust and front prop but you need to remove the 2 studs from the bottom front of the box, the rubber rear mount itself and the exhaust hangar bracket off the rear mount bracket (one bolt). With a bit of fiddling it will drop out.
  • OllieNZ
  • Visitor
  • Visitor
18 Jun 2016 16:48 #168796 by OllieNZ
I wanted to give the box a good clean up so I pulled it completely
[IMG
Also took the opportunity to fit an extended breather hose
[IMG
  • GraphicX
  • Visitor
  • Visitor
23 Jun 2016 06:34 #169032 by GraphicX
how are you finding the feel of the HD clutch, much heavier under the pedal ?
i fitted a new clutch when i swapped the motor, but it was an OEX or something & i'm unhappy with it, awful pedal feel & it tends to slip & stink of burning.
