Ollie's Lil Blue Jim.
  • OllieNZ
  • Visitor
  • Visitor
23 Apr 2016 09:30 #165679 by OllieNZ
Replied by OllieNZ on topic Re:Ollie's Lil Blue Jim.
Adjusted the valve clearances and sorted out the rocker cover leak this morning.
[IMG
Gave the sealing surface a quick clean
[IMG
A bead of loctite 515
And same under the gasket on the cover
[IMG
[IMG
Refit the gasket
[IMG
And then the cover.
I'm also really pleased with the effect of the damper on the steering. Highly recommend fitting one.
  • Daniel30
  • Visitor
  • Visitor
23 Apr 2016 15:39 #165689 by Daniel30
Replied by Daniel30 on topic Ollie's Lil Blue Jim.
Good job, the damper was the first thing I bought for mine definitely improves the feel of the steering ;)
  • OllieNZ
  • Visitor
  • Visitor
30 Apr 2016 15:15 #166040 by OllieNZ
Thanks,
Leak has definitely stopped.
Acquired a new (old) drill press.
[IMG
Surprised how much difference 250lbs in the back made to the ride. I was half tempted to leave it in there.
  • OllieNZ
  • Visitor
  • Visitor
26 May 2016 19:01 #167521 by OllieNZ
Well ladies and gentlemen, bad times for my Jimny. :(
It's been getting rougher when cold for a while and Monday morning it refused to start, missing, coughing and back firing out the intake. After finally coaxing it to life it seemed to settle as it warmed up so went off to work as normal.
Rough start again to come home so I decided to pull the idle control valve and plugs.
The idle control valve was a touch oily but not to bad at all. The plugs on the other hand, all seized into the head.
First plug out....
[IMG
Blasted thing sheared off and left the thread in the head. So I cracked the other three off slightly and left the lot to soak in plus gas overnight.
Next day......
[IMG
The sheared end came out fairly easily with an easy out but all 4 plugs stripped out the threads in the head.
Cue head removal (again :( )
And I located my starting issues......
[IMG
Cracks between the inlet and exhaust vales in two of the cylinders.
Refurbished head on the way for next week.
  • Daniel30
  • Visitor
  • Visitor
26 May 2016 19:12 #167524 by Daniel30
PANTS!!! hope you get it sorted soon ;)
  • OllieNZ
  • Visitor
  • Visitor
26 May 2016 19:16 #167526 by OllieNZ
Replied by OllieNZ on topic Re:RE: Ollie's Lil Blue Jim.
Daniel30 wrote: PANTS!!! hope you get it sorted soon ;)
Cheers,
I hope to have it back on the road next weekend but I'll see how I get on.
Time to create page: 0.141 seconds
