Leakage... transfer. Sorted thanks!
  • vitara_mad
02 Jan 2011 16:59 #8662 by vitara_mad
Replied by vitara_mad on topic Re: Leakage... transfer?
£3.50 delivered to your door you can't afford not to at that price
  • biggaz
02 Jan 2011 17:33 - 02 Jan 2011 17:46 #8670 by biggaz
Replied by biggaz on topic Re: Leakage... transfer?
Cheers guys, perfect!
yes martin, manual.. Ordered one off you thanks!
This just wear and tear then? So will i need to drain the oil in there before (75/90 oil yeh) and replace? Take it i will ulbolt at transfer end, then what? Is it straight forward?
Sorry really not sure with props, diffs, transfer box's lol! All this 4x4 stuff!
Last edit: 02 Jan 2011 17:46 by biggaz.
  • vitara_mad
02 Jan 2011 21:40 #8706 by vitara_mad
tbh it will be easyer if you take the transfer box off but you can do it while its still on just unbolt the prop & then undo the big nut holding the flange on the box & then you might need a puller to pull the flange off but not always sometimes they will come off easy
then replace seal & put back together
  • biggaz
02 Jan 2011 21:49 #8708 by biggaz
Ok mate cheers, think i will have a go in place first..
You think ill need to drain or just top-up?
cheers for the help, like to be prepared!
  • vitara_mad
02 Jan 2011 22:08 #8709 by vitara_mad
biggaz wrote: Ok mate cheers, think i will have a go in place first..
i personaly would drain & replace while your under there
03 Jan 2011 08:11 #8711 by facade
Replied by facade on topic Re: Leakage... transfer?
The drainplug needs thread sealant on it or it will drip.
(Most people dont bother and simply overtighten it.)
I used some locktite sealant that was knocking around the garage, but likely a tiny smear of stag/red heamatite/silicon will do.
Undo the filler plug before the drain plug in case the filler has been overtightened and wont come out.
